how to get digital 8bits data in the same and group the data in a digital value
i uses HCTL-2020 for decoding the INCREMENTAL ROTARY encoder signal . it has 8 pins to provide a 8 bits data. i don't know how to get the data in the same time and group the data in a DEC value
int dataPins[8] = {2,3,4,5,6,7,8,9};
    for (int i = 0; i< 8; i++)
         pinMode(dataPins[i], INPUT);
   int value = 0;
   for (int i=0; i<8; i++)
       value <<= 1;  // shift value left one bit
       value |= digitalRead(dataPins[i]);  // get a bit from a data pin
// Do something with value
johnwasser thx for your help . i found the result was 1111111 which was not the correct value from the decoder IC output. is it the shift occurred any problem? My latest program is following: is it have any problem?
int dataPins[8] = {30,31,32,33,34,35,36,37};
int SELPin = 38; //set SEL pin
int OEPin = 39; //set OE pin
int value;
int valuelow ;
int valuehigh ;
pinMode (SELPin, OUTPUT); //set SEL is output to control the decoder ic
pinMode (OEPin, OUTPUT); // set OE?is output to control the decoder ic
for (int i = 30; i<= 37; i++)
pinMode(dataPins*, INPUT);*
  • Serial.begin (9600);*
  • digitalWrite(SELPin, HIGH); // SEL = 1 when SEL and OE are 1 that means tell the ic ready to give data*
  • digitalWrite(OEPin, HIGH); // OE = 1*
  • digitalWrite(SELPin, LOW); // SEL = 0 when SEL and OE are 0 that means tell the ic send the low 8 bits data*
  • digitalWrite(OEPin, LOW); // OE = 0*
  • valuelow=0;*
  • valuehigh=0;*
  • for (int i=30; i<=37; i++)*
  • valuelow << 1; // shift value left one bit*
    _ valuelow |= digitalRead(dataPins*); // get a bit from a data pin*_
    /* digitalWrite(SELPin, HIGH); // SEL = 1 when SEL is 1 and OE are 0 that means tell the ic send the high 8 bits data
    * digitalWrite(OEPin, LOW); // OE = 0*
* for (int i=30; i<=37; i++)*
* valuehigh <<= 1; // shift value left one bit*
_ valuehigh |= digitalRead(dataPins*); // get a bit from a data pin*
// value=(valuehigh128)+valuelow; /
Serial.println(valuelow,BIN);
}*_
What are you using to provide the clock to the HCTL-2020?
johnwasser:
hello,I was using HCTL-2020 for decode 100 pulse per round encoder on maxon motor.
//int Data_Pins[8] = {46,47,48,49,50,51,52,53};
int SEL_Pin = 44; //set SEL pin
int OE_Pin = 43; //set OE pin
int RST_Pin = 42;
int CLK_Pin = 11;
//int value;
//int valuelow ;
//int valuehigh ;
void setup(){
    int pin;
    pinMode (SEL_Pin, OUTPUT);
    pinMode (OE_Pin, OUTPUT);
    pinMode (RST_Pin, OUTPUT);
    digitalWrite(RST_Pin, LOW);
    delay(100);
    digitalWrite(RST_Pin, HIGH);
    pinMode (CLK_Pin, OUTPUT);
    TCCR1A = B01000011; // Fast PWM change at OCR1A
    TCCR1B = B11001;  // System clock
    OCR1A = 0; // 8 MHz
    for (pin=46; pin <= 53; pin++){
        pinMode (pin, INPUT);
    Serial.print ("Start");
void loop(){
    int i;
	int j;
        int s;
	digitalWrite(SEL_Pin, LOW); // SEL = 0
	digitalWrite(OE_Pin, LOW); // OE = 0
	delay(100);
	String StrCombine ;
	for (i=46; i <= 53; i++){
	    StrCombine += digitalRead(i);
	digitalWrite(SEL_Pin, HIGH); // SEL = 1
        delay(100);
	for (j=46; j <= 53; j++){
	StrCombine += digitalRead(j);
    //   StrCombine=s;
	digitalWrite(OE_Pin, HIGH); // OE = 1
	Serial.println(StrCombine);
I got the code in this Forum.But it can not run on my mega 2560.
the output is 0000000011111111.
Could you help me,thanks a lot!
The data is sitting on 8 pins waiting to be read? Do you have an entire port available?
incoming Value = PINB; for instance reads all the pins of Port B at one time.
Try this version:
const int Data_Pins[8] = {46,47,48,49,50,51,52,53};
int RST_Pin = 42;
int CLK_Pin = 11;
  // Reset the chip
  delay(100);
  OCR1A = 0; // 8 MHz
 for (int i=0; i<8; i++) {
    pinMode(Data_Pins[i], INPUT);
  unsigned long value = 0;
  // Read the high 8 bits
  delay(100);
  for (int i=0; i<8; i++){
    value = (value << 1) | digitalRead(Data_Pins[i]);
  // Read the low 8 bits
  delay(100);
  Serial.println(value, BIN);
  delay(1000);  // Keep the data rate reasonable
johnwasser: Try this version:...
Thank you for help!
I have tried your code, and i get output like this, which is like some random integer: 11111111 1000000011011111 11111111 11001111 1000000011101111 1000000011001111 1000000011001111 1000000011001111 11001111 1000000011111111 1000000011111111 11001111 1000000011111111 11101111
And is my clock set right?
