Is there a way to use the GPRS capabilities of this board or something similar to increase the rate at which a GPS signal (from a connected GPS module) is obtained? I read that cellphones use the cell towers to estimate a position and give a GPS a sort of "starting point" that it can use to narrow down its search of satellites to connect to. Is this possible with this board? I'm using the Adafruit Ultimate GPS module.
There is example in MSKGSM library: MKRGSM/examples/GsmLocation at master · arduino-libraries/MKRGSM · GitHub .
