I am trying to build a GPS to display data on a TFT screen, but cannot get the data to update. The project is using an ESP32-S3 board, and Adafruit Ultimate GPS and Adafruit 1.69in TFT screen.
This is a simplified version. With buttons to change screens it only updates when changing screens. This version doesn't update the screen even though there is data available.
I have searched and tried various things. Please excuse my coding, I'm still new at this and just starting to use char instead of strings...
#include <Arduino.h>
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_ST7789.h> // Hardware-specific library for ST7789
#include <Adafruit_GPS.h> //Install the adafruit GPS library
#include <SPI.h> //Load SPI Library
#include <../fonts/FreeSans9pt7b.h>
#include <../fonts/FreeSans12pt7b.h>
#define TFT_DC 11
#define TFT_CS 9
#define TFT_RST 10
#define GPSSerial Serial1
#define GPSECHO false
Adafruit_GPS GPS(&Serial1); //Create GPS object
Adafruit_ST7789 display = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_RST);
uint8_t timeZone = 10;
uint8_t adjHour;
uint8_t adjDay;
uint8_t adjMonth;
uint8_t adjYear;
uint8_t velocity;
char c; //to read characters coming from the GPS
char lat = 'X'; ///< N/S
char lon = 'X'; ///< E/W
bool fix; ///< Have a fix?
char screenName[15];
char showPending[8] = "pending";
char displayBuf[20];
char floatBuf[20];
String lonStr;
String altStr;
String bearingStr;
unsigned long timer = millis();
static unsigned nextInterval = 1500;
GFXcanvas16 canvas(280, 240);
GFXcanvas16 cTopRow(280,30); // start at 0,0
GFXcanvas16 cBottom(280,20); // start at 0,220
GFXcanvas16 cMain(280,190); // start at 0,20
#define BLACK 0x0000
#define YELLOW 0xFFE0
#define GREEN 0x1f4d
#define DkGreen 0x0a62
#define DKRED 0xC800
#define BLUE 0x32FB
Serial.begin(115200); //Turn on serial monitor
GPS.begin(9600); //Turn on GPS at 9600 baud
GPS.sendCommand("$PGCMD,33,0*6D"); //Turn off antenna update nuisance data
GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA); //Request RMC and GGA Sentences only
GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ); //Set update rate to 1 hz
// Ask for firmware version
GPSSerial.println(PMTK_Q_RELEASE);
display.init(240,280); // this is the native resolution and rotation
display.fillScreen(BLACK);
display.setRotation(1);
display.setTextWrap(false);
readGPS();
gpsS1();
void readGPS() {
// read data from the GPS
char c = GPS.read();
if (GPSECHO)
if (c)
Serial.print(c);
// if a sentence is received, we can check the checksum, parse it...
if (GPS.newNMEAreceived()) {
if (!GPS.parse(GPS.lastNMEA())) // this also sets the newNMEAreceived() flag to false
return; // we can fail to parse a sentence in which case we should just wait for another
void gpsS1() {
strcpy(screenName, "GPS Main");
cMain.fillScreen(BLACK);
mainGrid("Latitude", "Altitude", "Longitude", "Heading"); // draws main grid lines & labels
cMain.setFont(&FreeSans12pt7b);
if(GPS.fix==1) {
float lon = GPS.longitudeDegrees;
lonStr = String((lon),4) + String(GPS.lon);
altStr = String((GPS.altitude),1) + " m";
bearingStr = String(GPS.angle);
clearMainGrid(); // clears areas for updating data
cMain.setTextColor(GREEN);
lonStr = "pending";
altStr = "pending";
bearingStr = "pending";
cMain.setTextColor(DkGreen);
if((millis() - timer) >= 500) {
timer = millis();
cMain.setCursor(22,58);
dtostrf(GPS.longitudeDegrees, 6, 4, floatBuf); // attempting to get data direct
cMain.print(floatBuf); // to see if that helps
cMain.print(GPS.lat); //
cMain.setCursor(162,58);
cMain.print(lonStr);
cMain.setCursor(35,152);
cMain.print(altStr);
cMain.setCursor(185,152);
cMain.print(bearingStr);
cMain.print((char)247);
display.drawRGBBitmap(0, 30, cMain.getBuffer(), cMain.width(), cMain.height());
topRow();
void mainGrid(String gh1, String gh2, String gh3, String gh4) { // draws main grid lines
cMain.drawLine(0,93,280,93,GREEN); // middle horizontal
cMain.drawLine(140,0,140,200,GREEN); // middle vertical
cMain.drawRect(0, 0, 280, 2, GREEN); // top divider
cMain.drawRect(0, 188, 280, 2, GREEN); // bottom divider
cMain.setFont(&FreeSans9pt7b); // headings myDate
cMain.setTextColor(BLUE);
cMain.setCursor(42,19);
cMain.print(gh1);
cMain.setCursor(45,113);
cMain.print(gh2);
cMain.setCursor(169,19);
cMain.print(gh3);
cMain.setCursor(183,113);
cMain.print(gh4);
void clearMainGrid() { // clears areas for updating data
cMain.fillRect(0, 24, 139, 67, BLACK);
cMain.fillRect(141, 24, 139, 67, BLACK);
cMain.fillRect(0, 118, 139, 67, BLACK);
cMain.fillRect(141, 118, 139, 67, BLACK);
void topRow() {
cTopRow.fillScreen(BLACK);
cTopRow.setFont(&FreeSans12pt7b);
cTopRow.setTextColor(YELLOW);
cTopRow.setCursor(15,27);
cTopRow.print(screenName);
if(GPS.fix) {
cTopRow.fillCircle(140,12,7,GREEN);
} else if(!GPS.fix) {
cTopRow.fillCircle(140,12,7,DKRED);
display.drawRGBBitmap(0, 0, cTopRow.getBuffer(), cTopRow.width(), cTopRow.height());
If anyone can help it would be appreciated.
