How to get historical data about a thing
Hi!
I want to fetch the historical values of a thing and believe that seriesV2HistoricData is the right function to call. However I am struggling to know what to fill in as property (uuid). I have tried with thing id, thing property id, and something called "user_id" which is returned by thingsV2List
I get this error flutter: {"id":"jl+qqBjn","code":"bad_request","status":400,"detail":"failed to decode request body with content type \"application/x-www-form-urlencoded; charset=utf-8\": is not a valid index for type []uuid.UUID"}
Can anyone help me how to request the historical data of a thing?
I've never done it but from the doc it seems you need to send something like this on a unix command line
curl -X POST "https://api2.arduino.cc/iot/v2/series/historic_data"
-H "Authorization: Bearer YOUR_ACCESS_TOKEN"
-H "Content-Type: application/json"
-d '{
   "from": "START_TIMESTAMP",
   "properties": ["PROPERTY_ID1", "PROPERTY_ID2"],
   "to": "END_TIMESTAMP"
(all in one line don't add the new lines, this is just tp make it readable)
you need to provide your access token, the timestamps and properties in a JSON
may be with flutter it could be something like
String apiUrl = "https://api2.arduino.cc/iot/v2/series/historic_data";
String accessToken = "YOUR_ACCESS_TOKEN";
void fetchData() async {
    final response = await http.post(
      Uri.parse(apiUrl),
      headers: {
        "Authorization": "Bearer $accessToken",
        "Content-Type": "application/json",
      body: jsonEncode({
        "to": "END_TIMESTAMP",
    if (response.statusCode == 200) {           // Successfully fetched data
      final data = jsonDecode(response.body);
      print(data);
    } else {                                    // Handle error
      print("Error: ${response.statusCode}");
      print("Response: ${response.body}");
I have tried with thing id and thing pid, e.g.:
  String history = "";
  List<String> properties = [
    "thing id / thing pid",
  try {
      Uri.parse("https://api2.arduino.cc/iot/v2/series/historic_data"),
      body: {
        "from": "2023-09-05",
        "properties": json.encode(properties),
        "to": "2023-09-07",
      headers: {"Authorizatoin": "Bearer $arduinoAccessToken"},
    history = response.body;
  } catch (e) {
    print(e);
  return history;
but still get {"id":"KXaV5G48","code":"bad_request","status":400,"detail":"failed to decode request body with content type \"application/x-www-form-urlencoded; charset=utf-8\": is not a valid index for type []uuid.UUID"}
Do you have any clue what I need instead for the property?
you use
it seems the content type should be application/json according to the documentation you pointed at
hence my suggested
the properties seems to be UUIDs
Adding the Content-Type header seems to be solving some issue, although now i get {"id":"RtnAsibk","code":"unauthorized","status":401,"detail":"not authorized"}
Even though I have a valid access token. Do you know what could cause this?
did you spell Authorization correctly (you had Authorizatoin)
did you use IDs for these ?
Thanks.. That one was embarrasing. It seems as if I am getting closer. I do not receive any data but I hope playing around with the time will fix it.
we have all been there
:wink:
print the full answer, not just the body. you might get extra information.
if you did not provide the right IDs that could be a reason why the answer is empty
Seems as if this wasn't the function I wanted to query after all
Request sending of historical data of properties by email
So the request is working (why my mail inbox is filled with historical data unintentionally). I will look for some other function.
that's what the doc states
historic_data series_v2
may be you wanted * seriesV2BatchQuery or seriesV2BatchQueryRaw?
propertiesV2Timeseries seems very promising to being what I want. I now get the historical data. Thanks for all the help!
cool
have fun
