#include <SoftwareSerial.h>
SoftwareSerial gsm(10, 11);
String Buffer;
String inData;
int i;
int *year, *month, *day, *hour, *minute, *second;
gsm.begin(9600);
delay(5000);
Ansh:
gsm.println(“AT+CCLK?\r\n”);
while (gsm.available()) {
char recieved = gsm.read();
inData += recieved;
delay(100);
// Process message when new line character is recieved
if (recieved == ‘\n’)
Serial.print("Arduino Received: ");
Serial.println(inData);
if (inData.substring(1, 5) == “+CCLK”) {
Serial.println(“Hello”);
// You can put some if and else here to process the message juste like that:
if (inData == “+++\n”) { // DON’T forget to add “\n” at the end of the string.
Serial.println(“OK. Press h for help.”);
inData = “”; // Clear recieved buffer
goto Ansh;
/* Buffer = Buffer.substring(Buffer.indexOf(""") + 1, Buffer.lastIndexOf(""") - 1);
year = Buffer.substring(0, 2).toInt();
month = Buffer.substring(3, 5).toInt();
day = Buffer.substring(6, 8).toInt();
hour = Buffer.substring(9, 11).toInt();
minute = Buffer.substring(15, 17).toInt();
second = Buffer.substring(18, 20).toInt();
Serial.println(*hour);
delay(100);
Serial.println(*minute);
delay(100);
Serial.println(*second);
delay(100);
But I don’t get live output but after 1 correct output it returns garbage as follows
12:22:38.960 → Arduino Received: +CCLK: “20/10/04,12:22:31+22” 12:22:38.960 → 12:22:39.672 → Arduino Received: 12:22:39.672 → 12:22:40.596 → Arduino Received: OK 12:22:40.596 → 12:22:42.339 → Arduino Received: AT+CCLK?
12:22:42.339 → 12:22:44.362 → Arduino Received: +CCAT+CCLK?
12:22:44.362 → 12:22:46.067 → Arduino Received: AT+CCLK?
12:22:46.067 → 12:22:50.344 → Arduino Received: +CCLK: "20/10/04,12ATAT+CAT+CCLK?
12:22:50.344 → 12:22:52.043 → Arduino Received: AT+CCLK?
12:22:52.043 → 12:22:54.082 → Arduino Received: +CCAT+CCLK?
12:22:54.082 → 12:22:55.822 → Arduino Received: AT+CCLK?
12:22:55.822 → 12:23:00.064 → Arduino Received: +CCLK: "20/10/04,12:22:49AT+CCLK?
12:23:00.098 → 12:23:01.791 → Arduino Received: AT+CCLK?
12:23:01.791 → 12:23:03.810 → Arduino Received: +CCAT+CCLK?
12:23:03.845 → 12:23:05.552 → Arduino Received: AT+CCLK?
12:23:05.552 → 12:23:09.803 → Arduino Received: +CCLK: "20/10/04,12:22:58AT+CCLK?
12:23:09.838 → 12:23:11.544 → Arduino Received: AT+CCLK?
12:23:11.544 → 12:23:13.563 → Arduino Received: +CCAT+CCLK?
12:23:13.563 → 12:23:15.290 → Arduino Received: AT+CCLK?
12:23:15.290 → 12:23:19.557 → Arduino Received: +CCLK: "20/10/04,12:23:08AT+CCLK?
12:23:19.557 → 12:23:21.278 → Arduino Received: AT+CCLK?
if I remove the delays from the code then I receive the following output
12:34:56.406 → Arduino Received: (⸮⸮SCC⸮⸮CL?⸮
1-⸮
AT+CCLK?
AT+CCL~Q⸮ -j 12:34:56.473 → 12:34:56.541 → Arduino Received: ⸮5⸮⸮AT+CCLK?
⸮⸮⸮~⸮⸮ 1⸮j⸮b-⸮
AT+CCLK?
AT+C⸮~⸮⸮ 1-j⸮5⸮⸮(⸮i 1-⸮
AV⸮1-j 12:34:56.607 → 12:34:56.913 → Arduino Received: ⸮5⸮⸮J⸮jj⸮j AT+CCLK?
AT+CCLK?
AT+CCLK?
AT+CK5Q⸮ 1⸮j⸮5⸮⸮AT+CCLK?
AT+CCLK?
AT+CCLK?
AT+CCLK?
AT+CCLK?
AT+CCLK⸮Q⸮ Zj⸮5⸮⸮(⸮⸮1-⸮
1⸮j⸮5j⸮ը(⸮CCP⸮i 1-⸮5Q⸮⸮j⸮jj⸮ը(j⸮jQb⸮⸮E⸮jj⸮(⸮⸮1-⸮5Q⸮ Zj⸮5⸮⸮(⸮⸮(j⸮jQ⸮Zj⸮5j⸮ը(⸮j⸮⸮ 1⸮j⸮⸮5j⸮(⸮⸮(⸮j⸮V 1-j 12:34:57.184 → 12:34:57.252 → Arduino Received: ⸮5⸮⸮D⸮j1-⸮
AT+CCLK?
AT+CCLK?
AT+CCLK?
AT+CCLK?
AT+CCLK?
A 1-⸮
AT+CCLK?
AT+CCLK?
AT+CCLK?
AT+CCL~Q⸮ -j 12:34:57.354 → 12:34:57.561 → Arduino Received: ⸮5⸮⸮AT+CCLK?
AT+CCLK?
AT+CCLK?
AT+CCLK?
AT+CCLK?
AT+CCLK? j AT+CCLK?
AT+CCLK?
AT+CCLK?
AT+CCLK?
AT+C⸮⸮5Q⸮⸮⸮Ԋi⸮j⸮(Q⸮⸮j⸮jj⸮ը(⸮CCP⸮i⸮j⸮ը(⸮CC⸮⸮⸮K? ⸮+CCLK?
AT+C⸮Q⸮Zj⸮5⸮⸮(Q⸮ -j 12:34:57.763 → 12:34:57.763 → Arduino Received: ⸮5⸮⸮E⸮jj⸮j AT+CCLK?
AT+CCLK?
AT+CCLK?
AT+CCLK?
AT+CCLK?
AT⸮⸮z⸮⸮z⸮⸮b⸮⸮Қ⸮Ҫ⸮Z⸮⸮j 12:34:57.866 → 12:34:57.866 → Arduino Received: 12:34:57.905 → 12:34:57.905 → Arduino Received: OK 12:34:57.968 → 12:34:57.968 → Arduino Received: AT+CCLK?
12:34:57.968 → 12:34:57.968 → Arduino Received: +CCLK: “20/10/04,12:34:54+22” 12:34:58.037 → 12:34:58.037 → Arduino Received: 12:34:58.070 → 12:34:58.070 → Arduino Received: OK 12:34:58.070 → 12:34:58.070 → Arduino Received: AT+CCK ⸮⸮'I⸮)j⸮H(⸮5⸮ꨨH⸮)⸮Қ⸮Ҫ⸮Z⸮⸮j 12:34:58.138 → 12:34:58.138 → Arduino Received: 12:34:58.172 → 12:34:58.172 → Arduino Received: OK A+⸮1-⸮jRb҂⸮jjZ⸮⸮Ҫ⸮Z⸮⸮j 12:34:58.207 → 12:34:58.207 → Arduino Received:
