I am using an Uno and Mega 2560. I am also using the official GSM shield.
Is it possible to extract the MAC address of the Arduino and/or the MAC address of the GSM shield? If so, how do I do that?
Thank you in advance.
It doesn't look as if this is possible
The library doesnt have a function for it, and if you look in the AT command set for the module that the sheild uses, I can't see anything about mac address
I think this is the doc for the commands
http://www.acmesystems.it/datasheets/GSM_ATC_AN_V1.1.pdf
but you'd need to double check.
BTW. You are better of posting to the networking board on this forum not the programmming one
The Arduino doesn't have a MAC address.
No.
@paulS
I presumed he meant the GSM module ![]()
I think that only ethernet devices have a mac address.
michinyon:
Many different types of network interfaces use the same concept of a MAC address. They are not interchangeable in the sense that you can't use a WiFi MAC address as an Ethernet MAC address, but they are conceptually equivalent in that they represent a physical layer interface to a network.
Thank you everyone for your replies.
In the end, to solve that problem, I used IMEI instead. ![]()
