how to get my data on xively??
what am i doing wrong here?
// include all Libraries needed:
#include <Process.h>
#include <Bridge.h>
#define APIKEY “???” // replace your pachube api key here
#define FEEDID ??? // replace your feed ID
#define USERAGENT “???” // user agent is the project name
// set up net client info:
const unsigned long postingInterval = 60000; //delay between updates to xively.com
unsigned long lastRequest = 0; // when you last made a request
String dataString = “”;
// start serial port:
Bridge.begin();
while(!Serial); // wait for Network Serial to open
Serial.println(“Xively client”);
// Do a first update immediately
updateData();
sendData();
lastRequest = millis();
// get a timestamp so you can calculate reading and sending intervals:
long now = millis();
// if the sending interval has passed since your
// last connection, then connect again and send data:
if (now - lastRequest >= postingInterval) {
updateData();
sendData();
lastRequest = now;
void updateData() {
// convert the readings to a String to send it:
dataString = “Temperature,”;
dataString += random(10) + 20;
// add pressure:
dataString += “\nPressure,”;
dataString += random(5) + 100;
// this method makes a HTTP connection to the server:
void sendData() {
// form the string for the API header parameter:
String apiString = "X-ApiKey: ";
apiString += APIKEY;
// form the string for the URL parameter:
String url = “https://api.xively.com/v2/feeds/”;
url += FEEDID;
url += “.csv”;
// Send the HTTP PUT request
// Is better to declare the Process here, so when the
// sendData function finishes the resources are immediately
// released. Declaring it global works too, BTW.
Process xively;
Serial.print("\n\nSending data… “);
xively.begin(“curl”);
xively.addParameter(”-k");
xively.addParameter("–request");
xively.addParameter(“PUT”);
xively.addParameter("–data");
xively.addParameter(dataString);
xively.addParameter("–header");
xively.addParameter(apiString);
xively.addParameter(url);
xively.run();
Serial.println(“done!”);
// If there’s incoming data from the net connection,
// send it out the Serial:
while (xively.available()>0) {
char c = xively.read();
Serial.write(c);
Thanks
