How to get PPM output from Futaba FP-T4L?
I just got a Futaba FP-T4L 4 channel 72 MHz R/C transmitter from a yard sale. I opened it up and there is no PPM output. The whole radio system is on a single PCB with the wires from the joysticks going to it. I have no receiver for it and want to replace the radio system with a 2.4GHz module. How would I go about doing that? Has anyone done this before?
Here is the last picture.
EDIT Some progress. The PCB is split into 2 parts and a IC on it is labeled "L9362". The thing is powered by 8 NiMH batteries. There is also a power indicator which goes up to just above the red section. The indicator is on the front.
Replace the electronics with a Promini and a nrf24L01+ module?
http://yourduino.com/sunshop2/index.php?l=product_detail&p=191
maybe this for power source
http://yourduino.com/sunshop2/index.php?l=product_detail&p=467
Well, I just went on RCGroups.com and found out that the L9362 chip is well known and has PPM output on pin 9. I think I will need a resistor divider. What resistor values should I use to reduce 9.6V to 5V?
The transmitter PPM output appears to not be giving me anything, so I have decided to use it as either a trainer or a joystick with UnoJoy.
