How to get PVM data (servo) in Arduino Nano from FS-i6Ab using IBUS Software
#include <iBUS.h>
// GO
#define UPDATE_INTERVAL 500
#include <iBUSTelemetry.h>
#include <AltSoftSerial.h>
AltSoftSerial sw_ser = AltSoftSerial(8, 9);
iBus ibus(sw_ser);
iBUSTelemetry telemetry(11); // I use only PCINT0 interrupt vector, so you can use D8 to D13 pins.
    D8 .. D13 - генерируют запрос прерывания PCINT0
    A0 .. A5  - генерируют запрос прерывания PCINT1
    D0 .. D7  - генерируют запрос прерывания PCINT2
uint32_t prevMillis = 0; // Necessary to updateValues() method. Look below.
float i = 0;
int channels_per_packet = 14;
uint32_t last_print = 0;
const int PERIOD = 50;
const int channels = 6;
void updateValues()
  uint32_t currMillis = millis();
  if (currMillis - prevMillis >= UPDATE_INTERVAL) { // Code in the middle of these brackets will be performed every 500ms.
    prevMillis = currMillis;
    telemetry.setSensorValueFP(1, i); // Now, you have two ways to set sensors values. Using floating point variables
    // or directly in 32bit integer, but then you have to format variable by yourself.
    // Ex.: telemetry.setSensorValueFP(1, 24.45); is equivalent to telemetry.setSensorValue(1, 2445);
    // The values differ for different sensors.
    telemetry.setSensorValue(2, telemetry.gpsStateValues(3, 8)); // As GPS status consists of two values,
    // use gpsStateValues(firstVal, secondVal) to set it properly.
    telemetry.setSensorValue(3, 123 * 10);
    telemetry.setSensorValue(4, 179583647); // You can set LAT / LON using FP metohod, but due to fact floats have only 6 digits precision,
    // your values on tx may be corrupted in some cases. It's better to use setSensorValue().
    telemetry.setSensorValue(5, UNARMED); // ARMED / UNARMED or 1 / 0 could be used.
    telemetry.setSensorValue(6, LOITER); // Available flight modes:     STAB   0
    // ACRO   1
    // AHOLD  2
    // AUTO   3
    // GUIDED 4
    // LOITER 5
    // RTL    6
    // CIRCLE 7
    // PHOLD  8
    // LAND   9
    telemetry.setSensorValueFP(7, 54.87);
    i += 0.1;
    if (i > 50)
      i = 0;
    // These were the most difficult sensors to use. I hope that this library will be useful for you and will make your work easier. :)
} /* updateValues */
void print_channels()
  // Only print every PERIOD ms
  if (millis() - last_print > PERIOD)
    last_print = millis();
    for (int i = 0; i < channels; i++)
      Serial.print("ch "); Serial.print(i + 1); Serial.print(": "); Serial.print(ibus.get_channel(i));
      if (ibus.is_alive())
        digitalWrite(LED_BUILTIN, LOW);
        Serial.println(" !!LINK DEAD!!");
        digitalWrite(LED_BUILTIN, HIGH);
    Serial.print("Last valid packet was received "); Serial.print(ibus.time_since_last()); Serial.println(" ms ago");
  while (!Serial) // On USB CDC serial ports, wait for the serial connection.
  // Set timeout between received packets to 20 ms before considering it a lost connection
  ibus.set_alive_timeout(200);
  // Set minimum time between transmitting packets, to 5ms
  ibus.set_tx_period(50);
  pinMode(LED_BUILTIN, OUTPUT);
  Serial.println("iBus test");
  telemetry.begin(); // Let's start having fun!
  telemetry.addSensor(0x01); // You can use sensors definitions from iBUSSensors.h instead of numbers.
  // Ex.: telemetry.addSensor(IBUS_MEAS_TYPE_TEM);
  telemetry.addSensor(IBUS_MEAS_TYPE_GPS_STATUS);
  telemetry.addSensor(IBUS_MEAS_TYPE_SPE);
  telemetry.addSensor(IBUS_MEAS_TYPE_GPS_LAT);
  telemetry.addSensor(IBUS_MEAS_TYPE_ARMED);
  telemetry.addSensor(IBUS_MEAS_TYPE_FLIGHT_MODE);
  telemetry.addSensor(IBUS_MEAS_TYPE_ALT);
  updateValues(); // Very important! iBUS protocol is very sensitive to timings.
  // DO NOT USE ANY delay()! Look at updateValues() method.
  // It's an example of how to use intervals without delays.
  telemetry.run(); //It must be here. Period.
  ibus.handle(); // Run this often
  // Reduce all channels by 50%
  for (int i = 0; i < channels_per_packet; i++)
    int old_value = ibus.get_channel(i);
    Serial.print("old_value = "); Serial.println(old_value);
    // map the old value (1000 to 2000) to a new value going from 1250 to 1750
    int new_value = map(old_value, 1000, 2000, -50, 50);
    Serial.print("new_value = "); Serial.println(new_value); Serial.println();
    // Set this new value to be sent on the next handle()
    ibus.set_channel(i, new_value);
  // The above will mess with the throttle, so fix the throttle channel separately
  // Channels are zero-indexed.
  //int x = ibus.set_channel(2, map(ibus.get_channel(2), 1000, 2000, -100, 100));
//Serial.print("x = "); Serial.println(x); Serial.println();
  //print_channels();
This telemetry code shows well, <iBUS.h> does not work. Libraries:
https://github.com/UA6EM/AltSoftSerial
https://github.com/UA6EM/iBUS
Please help with the code. I've been trying to find suitable libraries for a long time, but to no avail.
