How to get real-time feedback when controlling relays manually
I am using Arduino IoT cloud and ESP8266 board for an Alexa Home Automation project. In this project, I can control relays with Alexa and manual switch.
But when I am controlling the relays manually from the switch, I can not update the real-time status to Arduino IoT cloud from ESP8266 board.
Can anyone help me with this?
Thanks & Regards,
Subhajit
it's common to use a 2nd relay contact to indicate the state of the relay to some other device. (yes, you need a double pole relay)
Hi @techstudycell_projects
can you post the schematic of your project?
RV mineirin
Your microcontroller can detect voltage on IO-pins.
If you have a wifi-connection this offers sending data over WiFi.
I'm not familiar with Alexa. I will NEVER use it. But I guess alexa has a lot of Interfaces
best regards Stefan
You could “manually” operate the relays via digital inputs , then you 8266 will know the status of the relays.
I’ve never tried sending stuff back to Alex’s only the other way around - there is stuff on the internet for this , possibly the easiest way is to fool Alexa into thinking you have some commercial device that already has the skills set made .
