How to get RGB value of color picker in esp32 from webserver
Hello mates,
I'm new esp32 and webserver and have a little knowledge about data parsing from the webserver. What I'm trying to achieve is trying to get the RGB values in variable in esp32 so that i can use them to change my matrix display color.
Here is my code, may be this will give a clear idea.
//Libraries to configure esp32 with wifi and
//to establish connection b/w esp32 and webpage
#include <WiFi.h>
#include <WiFiUdp.h>
#include <NTPClient.h>
#include <AutoConnect.h>
#include <WiFiManager.h>
#include "SPIFFS.h"
#include "FS.h"
#include <AsyncTCP.h>
#include <ESPAsyncWebServer.h>
char ssid[] = "Rnd";
char pass[] = "XHBACDFH";
//SERVER PORTION
const char* PARAM_STRING = "inputString";
const char* PARAM_COLORVALUE = "inputColorValue";
// HTML web page to handle 2 input fields (inputString, inputColorValue)
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html><head>
  <title>ESP Input Form</title>
  <meta name="viewport" content="width=device-width, initial-scale=1">
  <script>
    function submitMessage() {
      alert("Saved value to ESP SPIFFS");
      setTimeout(function(){ document.location.reload(false); }, 500);
  </script></head><body>
//This custom text function is woring very fine
  <!--Custom Text-->
  <form action="/get" target="hidden-form">
    inputString (current value %inputString%): <input type="text" name="inputString">
    <input type="submit" value="Submit" onclick="submitMessage()">
  </form><br>
//But this is getting error (Error is : failed to open file or writing, the value when i choose from server it shows at the Serial.print() but it is not writing in the SPIFFS and shows "failed to open file or writing")
  <!--Color picker-->
    inputColorValue (current value %inputColorValue%):
    <h2>Color Picker</h2>
    <input type="color" name="inputColorValue">
  </form><br>
  <iframe style="display:none" name="hidden-form"></iframe>
</body></html>)rawliteral";
void notFound(AsyncWebServerRequest *request) {
  request->send(404, "text/plain", "Not found");
String readFile(fs::FS &fs, const char * path){
  Serial.printf("Reading file: %s\r\n", path);
  File file = fs.open(path, "r");
  if(!file){ // || file.isDirectory()
    Serial.println("- empty file or failed to open file");
    return String();
  Serial.println("- read from file:");
  String fileContent;
  while(file.available()){
    fileContent+=String((char)file.read());
  Serial.println(fileContent);
  return fileContent;
void writeFile(fs::FS &fs, const char * path, const char * message){
  Serial.printf("Writing file: %s\r\n", path);
  File file = fs.open(path, "w");
  if(!file){
    Serial.println("- failed to open file for writing");
    return;
  if(file.print(message)){
    Serial.println("- file written");
    Serial.println("- write failed");
String processor(const String& var){
  //Serial.println(var);
  if(var == "inputString"){
    return readFile(SPIFFS, "/inputString.txt");
  }else if(var == "inputColorValue"){
    return readFile(SPIFFS, "/inputColorValue.txt");
  return String();
//Set up code
void setup(){
   if(!SPIFFS.begin(true)){
      Serial.println("An Error has occurred while mounting SPIFFS");
      return;
WiFi.begin(ssid, pass);
    Serial.print(".");
  Serial.println("");
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
    server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send_P(200, "text/html", index_html, processor);
    server.on("/get", HTTP_GET, [] (AsyncWebServerRequest *request) {
    String inputMessage;
    if (request->hasParam(PARAM_STRING)) {
      inputMessage = request->getParam(PARAM_STRING)->value();
      writeFile(SPIFFS, "/inputString.txt", inputMessage.c_str());
    else if(request->hasParam(PARAM_COLORVALUE)){
      inputMessage = request->getParam(PARAM_COLORVALUE)->value();
      writeFile(SPIFFS, "inputColorVlaue.txt", inputMessage.c_str());
    else {
      inputMessage = "No message sent";
    Serial.println(inputMessage);
    request->send(200, "text/text", inputMessage);
    server.onNotFound(notFound);
    server.begin();
void loop(){
  String yourInputString = readFile(SPIFFS, "/inputString.txt");
  Serial.print("*** Your inputString: ");
  Serial.println(yourInputString); //here it prints what i input at server and prints the text
  String yourInputColorVlaue = readFile(SPIFFS, "/inputColorVlaue.txt");
  Serial.print("*** Your inputColorVlaue: ");
  Serial.println(yourInputColorVlaue); //but here i dont get anything what input at server
Can anyone tell me where I'm doing wrong or pls if you have any solution pls assist, I'll be grateful..
Thanks and Regards..
Different from your approach, but here is my "color collider" code. It moves 2 different colors to the center of the string and changes a few middle LEDs to be color of the 2 "colliding" colors. It is set up as a stand alone access point, so if you want to use it in station mode you need to change the WiFi set up. The code you are probably interested in is in the handleRoot() routine.
#include <NetworkInfo.h>
#include <TransmissionResult.h>
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266HTTPUpdateServer.h>
ESP8266WebServer server(80);   // web server on standard port
ESP8266HTTPUpdateServer httpUpdater;
#include <DNSServer.h>
const byte DNS_PORT = 53;     // name server on standard port
IPAddress apIP(192, 168, 6, 1);   // IP address to use in non-routed range
DNSServer dnsServer;
#include <FS.h>
#include <user_interface.h>
#include <string.h>
#include <Streaming.h>   //  from "Streaming by Mikal Hart" in library manager
const char* ap_ssid     = "Colors"; // Default AP ssid if board ID not found
const char* ap_password = "lightupleds";   // AP Password
const char* host = "www.leds.com";       //  DNS host name
#include <NeoPixelBus.h>
const uint16_t pixelCount = 144;
#define colorSaturation 127
// three element pixels, in different order and speeds
// For Esp8266, the Pin is omitted and it uses GPIO3 due to DMA hardware use.
NeoPixelBus<NeoGrbFeature, Neo800KbpsMethod> strip(pixelCount);
RgbColor red(colorSaturation, 0, 0);
RgbColor green(0, colorSaturation, 0);
RgbColor blue(0, 0, colorSaturation);
RgbColor white(colorSaturation);
RgbColor black(0);
RgbColor leftColor = red;
RgbColor rightColor = green;
bool firstTime = true;
void handleRoot(){
  String htmlPage;
  htmlPage.reserve(3800); // reserve space for HTML page
  if (server.hasArg("lred")) {
    // we have input data - assume they are all set
    leftColor = RgbColor(server.arg("lred").toInt(),server.arg("lgreen").toInt(),server.arg("lblue").toInt());
    rightColor = RgbColor(server.arg("rred").toInt(),server.arg("rgreen").toInt(),server.arg("rblue").toInt());
    firstTime = true;
   // Fill in static part of page
   htmlPage =
  " <!DOCTYPE HTML>\n\
<html lang='en'>\n\
 <head>\n\
    <meta name='viewport' content='width=device-width, initial-scale=1.0'>\n\
    <title>Color Collider</title>\n\
</head>\n\
\n\
\n\
<body onload='changeRGB()'>\n\
    <h1 style='text-align: center;'>Color Collider color selector</h1>\n\
    <br>\n\
    <h2 id='collide'>Pick colors to collide</h2>\n\
    <form>\n\
      <p id='lside'> Left Side </p>\n\
      <div>\n\
      <label for='lred' id='lrlab'>Red Value</label><br>\n\
      <input type='range' id='lred' name='lred' min='0' max='127'  onchange='changeRGB()'\n\
       value=";
 htmlPage += leftColor.R ;
 htmlPage +=
    "   \n\
      >\n\
      </div>\n\
      <div>\n\
      <label for='lgreen' id='lglab'>Green Value</label><br>\n\
      <input type='range' id='lgreen' name='lgreen' min='0' max='127' onchange='changeRGB()'\n\
      value=";
 htmlPage += leftColor.G ;
 htmlPage +=
    "   > \n\
      </div>\n\
      <div>\n\
      <label for='lblue' id='lblab'>Blue Value</label><br>\n\
      <input type='range' id='lblue' name='lblue' min='0' max='127' onchange='changeRGB()' \n\
      value= ";
 htmlPage += leftColor.B ;
 htmlPage +=
      " \n\
       </div>\n\
      <p id='rside'> Right Side </p>\n\
      <div>\n\
      <label for='rred' id='rrlab'>Red Value</label><br>\n\
      <input type='range' id='rred' name='rred' min='0' max='127'  onchange='changeRGB()' \n\
      value=";
 htmlPage += rightColor.R ;
 htmlPage +=
      " >\n\
      </div>\n\
      <div>\n\
      <label for='rgreen' id='rglab'>Green Value</label><br>\n\
      <input type='range' id='rgreen' name='rgreen' min='0' max='127' onchange='changeRGB()'\n\
       value = ";
     htmlPage += rightColor.G ;
 htmlPage +=
     " > \n\
      </div>\n\
      <div>\n\
      <label for='rblue' id='rblab'>Blue Value</label><br>\n\
      <input type='range' id='rblue' name='rblue' min='0' max='127' onchange='changeRGB()'\n\
      value=";
 htmlPage += rightColor.B ;
 htmlPage +=
   "  >\n\
      </div>\n\
      <div>\n\
      <input type='submit' value='Set colors'>\n\
      </div>\n\
    </form> \n\
    <script>\n\
\n\
      function changeRGB() {\n\
        var lcol, lr, lg, lb, rcolor,rr,rg,rb,collidecolor,cr,cg,cb,cscale,cmax;\n\
        lr = document.getElementById('lred').value;\n\
        lg = document.getElementById('lgreen').value;\n\
        lb = document.getElementById('lblue').value; \n\
        lcolor = 'rgb('+ (Number(lr)*2) + ','+ (Number(lg)*2)+ ','+ (Number(lb)*2)+')';\n\
        rr = document.getElementById('rred').value;\n\
        rg = document.getElementById('rgreen').value;\n\
        rb = document.getElementById('rblue').value; \n\
        rcolor = 'rgb('+ (Number(rr)*2) + ','+ (Number(rg)*2)+ ','+ (Number(rb)*2)+')';\n\
        document.getElementById('lrlab').innerHTML = 'Red value '+ lr;\n\
        document.getElementById('lglab').innerHTML = 'Green value '+lg;\n\
        document.getElementById('lblab').innerHTML = 'Blue value '+lb;\n\
        document.getElementById('lside').style.backgroundColor = lcolor;\n\
   //     document.getElementById('lside').innerHTML = lcolor;\n\
        document.getElementById('rrlab').innerHTML = 'Red value '+ rr;\n\
        document.getElementById('rglab').innerHTML = 'Green value '+rg;\n\
        document.getElementById('rblab').innerHTML = 'Blue value '+rb;\n\
        document.getElementById('rside').style.backgroundColor = rcolor;\n\
        cr = Number(rr)+Number(lr);\n\
        cg = Number(rg)+Number(lg);\n\
        cb = Number(rb)+Number(lb);\n\
        cmax = Math.max(cr,cg,cb);\n\
        if (cmax == 0) {\n\
          cscale = 0;\n\
        }\n\
        else {\n\
          cscale = 254/cmax;\n\
        }\n\
        collidecolor = 'rgb(' + (cr*cscale) +',' +(cg*cscale) +',' +(cb*cscale) +')';\n\
        document.getElementById('collide').style.backgroundColor = collidecolor;\n\
      //  document.getElementById('collide').innerHTML = collidecolor;\n\
      }\n\
    </script>\n\
 </body>\n\
</html>\n";
 server.send(200, "text/html",htmlPage);
bool PixelEqual( RgbColor color1,RgbColor color2){
  if((color1.R == color2.R) &&
     (color1.G == color2.G) &&
     (color1.B == color2.B)){
      return true;
  else {
    return false;
  // Set up WiFi network
  WiFi.mode(WIFI_AP);
  WiFi.softAPConfig(apIP, apIP,IPAddress(255, 255, 255, 0));
  if (!WiFi.softAP(ap_ssid, ap_password)) {
     Serial.println("wifi connection  fail");
   //  while (true) {};    // hang until wdt forces a reset to retry
  Serial.println("wifi connected");
 // DNS
 // modify TTL associated  with the domain name (in seconds)
  // default is 60 seconds
  dnsServer.setTTL(300);
  // set which return code will be used for all other domains (e.g. sending
  // ServerFailure instead of NonExistentDomain will reduce number of queries
  // sent by clients)
  // default is DNSReplyCode::NonExistentDomain
  dnsServer.setErrorReplyCode(DNSReplyCode::ServerFailure);
  // start DNS server for a specific domain name
  dnsServer.start(DNS_PORT,host, apIP);
  // set web page handlers
  server.on("/", handleRoot);
  // Start the server
  httpUpdater.setup(&server);
  server.begin();
  // this resets all the neopixels to an off state
  strip.Begin();
  strip.Show();
  RgbColor merge; // combined color value
  dnsServer.processNextRequest();    // check for DNS request
  server.handleClient();             // check for connection request
  if (firstTime){
    // set the colors
    strip.ClearTo(black);
    for (int i =0; i<(pixelCount)/2;i+=6) {
      for(int j=0;j<4;j++){
        strip.SetPixelColor(i+j, leftColor );
        strip.SetPixelColor(pixelCount-(i+j+1), rightColor);
    strip.Show();
    firstTime = false;
  delay(50);
  // shift colors toward middle
  strip.RotateLeft(1,pixelCount/2,pixelCount-1);
  strip.RotateRight(1,0,(pixelCount/2)-1);
  // combine colors four away from middle and set them in pattern - the color may be black
  merge = RgbColor::LinearBlend(strip.GetPixelColor(68), strip.GetPixelColor(75), 0.50f);
  strip.SetPixelColor(68, merge);
  strip.SetPixelColor(75, merge);
  // if the end colors are not black correct for merged color after rotate
  if(!PixelEqual(strip.GetPixelColor(0), black)){
     strip.SetPixelColor(0,leftColor);
     strip.SetPixelColor(pixelCount-1,rightColor);
  strip.Show();
