I have Arduino: 1.8.19 on Windows 7 pro
The board is a Leonardo has worked well.
Lately I uploaded a sketch, in which I reset a time delay entry from :
analogWrite(redPin,bright/64); to analogWrite(redPin,bright/0);
(devision by zero), as expected it can't cope with this and stopped in its tracks.
Ok that's fine--> Ill just change zero back to an int and re-Upload.
But Nothing worked anymore.
To get the Leonardo board the accept Uploads again, I hit the reset button rapidly multiple times during Upload. (was also complaining about Java stuff)
After a few times, it finally accepted Uploads again.
BUT, now every time I upload a skech, I get the following: (Abreviated)
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .
Found programmer: Id = "CATERIN"; type = S
Software Version = 1.0; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:
Device code: 0x44
avrdude: devcode selected: 0x44
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% -0.00s
avrdude: Device signature = 0x1e9587 (probably m32u4)
avrdude: reading input file "C:\Users\Adrian\AppData\Local\Temp\arduino_build_777573/ReadAnalogActualVolt.ino.hex"
avrdude: writing flash (5596 bytes):
Writing | ################################################## | 100% 0.43s
avrdude: 5596 bytes of flash written
avrdude: verifying flash memory against C:\Users\Adrian\AppData\Local\Temp\arduino_build_777573/ReadAnalogActualVolt.ino.hex:
avrdude: load data flash data from input file C:\Users\Adrian\AppData\Local\Temp\arduino_build_777573/ReadAnalogActualVolt.ino.hex:
avrdude: input file C:\Users\Adrian\AppData\Local\Temp\arduino_build_777573/ReadAnalogActualVolt.ino.hex contains 5596 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.06s
avrdude: verifying ...
avrdude: 5596 bytes of flash verified
avrdude done. Thank you.
My question is:"Is there a way to get rid of this AVRDUDE stuff and go back to the original upload sequence"?
Many thanks for your help.
