How to get signal print from sensors to Monitor/LCD
I am working on project, in which signal or value from sensor like IDR,Ultrasound, etc is printed LCD monitor or in built display of IDE.
I am not able to find out how to do such complex circuitry and write code for it.
Can anyone help me to work with it?
Actually, a lot of sensor libraries have example code that does part of that, sends sensor readings to the serial monitor of the IDE. The rest, like connecting a sensor, is just basic internet research. It also depends on what sensor you use, which you apparently haven’t decided on yet.
Your question is too general to be answered easily. Provide some specifics and we may be able to help.
What Arduino board? What sensor? What exact display?
groundFungus:
I am using Arduino UNO,
sensors : LDR, IR, TEMP, FLAME etc( basically I want to make Program with Switch case between these sensor)
and print waveform obtain from it. on either TFT or OLED display
P.S did research i can't print waveform on 1602A LCD
