How to get stable values from mpu 6050 using DMP in static position?
I would like to get the stable values for Acceleration, Euler angles and Yaw, pitch and roll.
I connected MPU 6050 with the controller and using the same sketch as provided by Jeff Rowberg.
I put the sensor on the breadboard.
For acceleration I am getting different values. as in static position values must be 0,0,0 or closer to that. Same with angles it should give me something 90,90,0 or somehow similar.
I did not change anything in the sketch except baud rate to 38400.
Could anybody please help or suggest me in this regards?
Looking Forward anxiously.
Kind Regards,
Farhan
You say that you have different values.
How can we help with that ?
Can you dump the output of the serial monitor here ?
