How to get the client(s)of an Arduino ethernet server?
I would like to implement an inactivity timeout for my clients.
(It seems I cannot connect to my Arduino via ethernet because some connection are not properly closed)
How can I do that?
I have something like:
loop() {
Client incomingClient = server.available();
if (incomingClient) {
[read received command and process it]
// I enter here if
// no telnet connection
// or no activity on telnet link
incomingClient.println("disconnecting"); // <-- doesn't work obvisouly due to if condition
incomingClient.stop(); // <-- doesn't work for same reason
So the question is how can I timeout my ethernet connection?
Thanks,
Emmanuel
I used PuTTY to test this with a very simple "telnet". It echos your input to the serial monitor until you enter an 'x', or don't do anything for 10 seconds.
Change the network settings to your system.
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip( 192,168,2,2 );
IPAddress gateway( 192,168,2,1 );
IPAddress subnet( 255,255,255,0 );
EthernetServer server(23);
int loopCount = 0;
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  delay(2000);
  server.begin();
  Serial.println("Ready");
  if(client)
    Serial.println("Client connected");
    client.flush();
    Serial.flush();
    loopCount = 0;
    while (client.connected())
      while(client.available())
        char c = client.read();
        if(c == 'x') client.stop();
        else Serial.write(c);
        loopCount = 0;
      while(Serial.available()) client.write(Serial.read());
      delay(1);
      loopCount++;
      if(loopCount > 10000) client.stop();
    client.stop();
    Serial.println("disconnected");
edit: My bad. I forgot one client.stop(). Fixed.
This is a persistent connection. It does not close until you tell it to.
I also added a serial response. While the client is connected, you can send messages to the connected client with the serial monitor input.
