How to get the highest data from data array i2c device
i have an project with Omron D6T-8L . i want to show the highest data from the data i get in serial monitor. sorry for bad english. it’s not my first language.
// This script reads the data from a 8x1 OMRON D6T-8L sensor using only the Wire library. Note that use of D6T-44L 4x4 sensor general requires the WireExt.h library, so that the 35 bytes of data can be read from the sensor.
#include <Wire.h>
//#include <WireExt.h>
#define D6T_addr 0x0A // Address of OMRON D6T is 0x0A in hex
#define D6T_cmd 0x4C // Standard command is 4C in hex
int numbytes = 19;
int numel = 8;
int rbuf[19]; // Actual raw data is coming in as 35 bytes. Hence the needed for WireExt so that we can handle more than 32 bytes
int tdata[8]; // The data comming from the sensor is in 8 elements
float t_PTAT;
Wire.begin();
pinMode(13, OUTPUT);
int i;
int sum = 0;
// Step one - send commands to the sensor
Wire.beginTransmission(D6T_addr);
Wire.write(D6T_cmd);
Wire.endTransmission();
delay(70); // Delay between instruction and data acquisition
// Read from the sensor
// Need to send a read command here - but how will this work with 7 bit addressing?
Wire.requestFrom(D6T_addr,numbytes); // D6T-8 returns 19 bytes
// Receive the data
if (0 <= Wire.available()) { // If there is data still left in buffer
i = 0;
for (i=0; i < numbytes; i++) {
rbuf = Wire.read();
    t_PTAT = (rbuf[0] + (rbuf[1] << 8) ) * 0.1;
  • for (i = 0; i < numel; i++)*
    tdata = (rbuf[(i2+2)] + (rbuf[(i2+3)] << 8 )) * 0.1;
    _ sum += tdata*;
    Serial.print(tdata);
    Serial.print(",");
    }*_
* int average = sum/8;*
* Serial.println();*
* Serial.print ("average: ");*
* Serial.print (average);*
* Serial.print("\n");*
* delay(100); *
[/quote]
Edit your post and change the tags from quote to code. As you probably have noticed the forum system does not show the correct code above!
Explain what your problem is. What is the "highest" data? The biggest value received? The last bye? The first byte?
