How to get the JY-MCU bt board to work
Claghorn:
Scratchy:
when I type AT I get OK, but when I type AT+VERSION (or ATVERSION, like You said before) I get nothing.
Are you really typing keys with your fingers? If this is the same firmware my board has,
that will never work - it uses timing to decide when it has gotten a message, and no one
can type fast enough for long messages to satisfy it. Try using cut & paste into your
terminal app.
Cut and paste doesn't work either, that's the thing.
The serial monitor isn't a very good terminal. It may be sending a CR or LF or both at the end, my JY-MCU doesn't like those either. You need something that sends the last 'N' in version then stops sending :-). (Maybe the serial monitor can be set to no line ending? I forget).
Claghorn:
Yes, my serial monitor is set to no line ending.
Finally I changed baud rate with simple TTL to Serial cable connected to BT module. :slight_smile:
And finally uploaded sketch via bluetooth: http://arduino.cc/forum/index.php/topic,110532.0.html :slight_smile:
I have the exact same problem as the people above.
I too have an JY-MCU BT board as found here.
I use the standard SoftwareSerialExample program as found in the Arduino software. I have changed the communication between the JY-MCU and the Arduino to 9600 baud, instead of the 38400 mentioned by orangeLearner.
I then proceed to open up the standard Arduino terminal program, change the baudrate to 57600, and no line ending. I see 'Goodnight moon!'
Then I type 'AT' and press send. An 'OK' returns. All fine and dandy, but other than that AT command, no other AT commands like 'AT+VERSION' work. The module is just sitting there, flashing a red light. My iPhone also can't find any Bluetooth device, no 'Linvor' is showing up.
Can anyone shine a light on this one?
FreeBee:
Unfortunately yes: iOS won't talk simple serial bluetooth (RFCOMM) without you paying Apple a gazillion dollars and going through something like a Navy Seal training certification process :-). Either that or rooting your iPhone so you can install the stuff described at:
http://code.google.com/p/btstack/
Claghorn:
Google Code Archive - Long-term storage for Google Code Project Hosting.
So i'll need another device like an older phone with BT to check wether or not the BT module is broadcasting it's name and/or make connections?
FreeBee:
I guess - I don't think iPhones are missing BT, they just refuses to talk RFCOMM because (for some reason) that's the way Apple wants it. My Android phone works fine talking to my JY-MCU modules as does my linux box with a cheap bluetooth dongle plugged into a USB port (mine was sold by D-link).
I have the same problem with AT commands, only have AT working, non other. Is the problem in the software serial sketch maby? I don't have a usb to ttl board, only a usb to rs232 so I really need make it work over the arduino, any Ideas?
I've already got yhe propper interface and it's working, somehow the sketch for arduino doesnt do the job.
I had the same problems where only the AT command received a response. I have the breakout version 1.03 with firmware version 1.5. Found and changed a simple Arduino sketch to allow AT commands to be sent to the Bluetooth adapter. Simply adding a delay(10) allowed the other commands such as AT+VERSION to get a correct response from the Bluetooth adapter. I used Arduino's serial Monitor to send all the commands. This is based on the code in the link provided earlier in this thread. Hope this is useful to some!
Link to the code: http://eclipse.clinertech.com/arduino/bluetooth/blth.html
augustinoy:
Poppin, your code works with me. Something in the example code makes it unable to get a response from any other AT command. Nice job, it works here.
Links with the AT commands.
http://eclipse.clinertech.com/arduino/bluetooth/Bluetooth_AT_Commands.txt
Two key pieces of information I wish I knew when I started.
  1. AT commands DO NOT work when the device is paired.
  2. SoftwareSerial doesn't work past 9600 BAUD.
WARNING: Setting the BAUD Rate too high will essentially lock you out of the chip if you don't have hardware that can send/recieve at that baud rate...
This code above worked for me very well >.> until I changed the BAUD rate using AT+BAUD8
Now it's stopped responding to AT commands. ( I did recompile my sketch to use the new baud rate 115200)
There is a "STATE" Pin that I found on Krill Labs - Using the BT Board v1.02 JY-MCU
that says that will toggle it between AT command mode and regular work but I think maybe a 10k resistor is too much since I'm only running on 5V
I've also discovered that delay rates of tx/rx stuff changes pending on baud rate so maybe I'm failing there somehow. I was reading the SofwareSerial.cpp file and some other sources said timing is pretty important for this but unsure exactly how to calc it.
At one point I did have my snes controller -> Arduino Mega -> BlueTooth module -> custom compiled SNES9x >.> but I wanted faster response times.
Things would lock up alot and I got a reset procedure down.
Remove the pairing (ubuntu 12.04 LTS)
Reboot box
hcitool scan
rfcomm bind 0 00:12:02:28:71:34 1
screen /dev/rfcomm0 9600 #This will prompt you for the pairing password and I also noticed the LED went solid rather than blinky.
rfcomm release 00:12:02:28:71:34
UPDATE:
Got it working again, I switched to hardware tx3/rx3 then I cycled through every baud rate until I saw the right output, aparently I set it to 57600
run the following just once after boot, and note AT commands cannot be run after this is paired
hcitool scan
#Upload this test code
Serial3.begin(57600);
Serial3.write("test\r\n");
command line test
screen /dev/rfcomm0 57600 #cycle through all baud rates until you see the plain text "test" string
I re uploaded the sketch every time but when I hit 57600 I just decided to re run screen without the upload and it worked >.> so maybe it doesn't matter or maybe that fixed it.
Once I saw the plain text I CTRL-A-k out of screen
rfcomm release 00:12:02:28:71:34 #If you don't release the pairing AT commands don't work!
Then upload the following code
String command = "";
Serial.println("Type AT commands!");
void loop(){
if (Serial3.available()) {
while(Serial3.available()) { command += (char)Serial3.read();delay(10); }
Serial.println(command);
command = ""; // No repeats
if (Serial.available()){ delay(20); Serial3.write(Serial.read()); }
screen /dev/ttyACM0 115200 #Begin typing AT commands.
I just wrote up an Arduino sketch that configures this module if that is helpful to anyone.
http://arduino.cc/forum/index.php/topic,122070.0.html
I got my JY-MCU, but can't get it to work.
Wired with 5V @ 8A going in to Arduino VBus, BT, and 100 pixel LEDs. Pixel data on D4, TX/RX swapped from BT to Arduino (tried both ways).
  1. When powered, red light on it blinks continuously even with TX/RD unplugged, always, never seen any change.
  2. When paired I get 2 serial ports: "Com11 - SSP" and "Com12 - SSP (Dev B)". Windows lets me enable or disable 12 in BT settings. 11 is always only in device manager.
  3. When I try to open either port (at 9600), term program locks up for a few seconds, then says it is open but it doesn't work.
Seller said board default was 9600. I was hoping I could just plug this in and do everything (re-program Arduino, send bytes to change LED colors) the exact same as when I connect my TTL board to the same 4-pins and use a cable. The whole thing is installed on my roof, so I'd rather not have to send any AT commands while unpaired or any of that stuff, but I guess I could just pull the BT and connect it to my TTL if I have to.
Any suggestions? Which of the 2 serial ports is right? Is the red light supposed to blink no matter what?
rpmccormick:
Blinking red light is what I see as well, even with nothing attached to TX and RX. I think the light may change when it goes into command mode, but I don't recall offhand.
I haven't tried to reprogram an Arduino over the bluetooth serial link, but I don't see any reason why it wouldn't work.
I think your best bet is to get the Bluetooth module working on its own before trying to incorporate it into your project. The sketch I wrote should be able to configure the module to whatever you specify, regardless of what the default configuration is. From there, you can test it out with a simple "Hello World" kind of sketch and a Bluetooth terminal on the PC. The module will keep that configuration forever, so once you set it up once and get it working, you can just drop the module into the project on the roof and it should just work.
  1. Try using a very simple sketch that just outputs a message every second with just the Arduino first. Program it with a USB cable, then remove it from the computer and attach the JY-MCU so that the up arrow (on either RX or TX) goes to TX (pin 1) on the Arduino. If you connected it correctly then you should be able to see your data.
  2. When you pair and open the serial port (you have two-either one should work), the LED should shop blinking and be solid on. This means the serial port is open and you should be seeing data. You cannot send AT commands in this mode. If you want to send AT commands to change baud rate and name, follow steps in post #3. You cannot upload sketches in this mode unless you press the reset button at the right time. Uploading sketches requires a reset wire which the JY-MCU does not provide. I made an ATtiny circuit to watch the LED and reset the microcontroller so that sketches can be uploaded, but uploading code is five times slower and sometimes it fails. It is flawless if it actually finishes an upload though.
Thanks for the replies, I guess I'll pull it off and get it AT-programmed (even though any baud/pin/name is totally fine with me if I could just get it to work).
The solid-light on serial data is good to know... and you are saying both of the 2 serial ports do the same thing? Strange.
Ok...
  1. Connected board to TTL and AT commands were fine.
  2. Proved out 2-way communication by using BT, TTL, and two terminal programs.
  3. Proved 1-way communication when re-installed on Roof (Arduino code sends "RPM\n" on startup, and I see that in terminal program)
  4. SENDING BYTES DOES NOT SEEM TO WORK when installed on Roof???
It should not be my Arduino code, but I thought I would try to reprogram it anyway.
I changed the boards.txt file to 9600 baud (didn't want to risk upping it, AT verified 9600)
When I try to program my Arduino Mini Pro, it just says "uploading..." and locks up the port until I reboot. When using the TTL, it never does this; it times out after 5-seconds if you don't press reset in time. I had my friend on the roof pressing reset, but even if our timing was off, it should time-out, not lockup. What is going on?
If you have already verified two-way communication without a USB cable while not on the roof, then it should work on the roof unless a wire comes loose or the asymmetry between Bluetooth transmit power causes one of the two signals to degrade.
I do not know why your computer is locking up while trying to program over bluetooth. If I had to guess, it is getting stuck at the connection establishment, something a USB cable does not have to worry about. I would just end the Arduino process or disable the bluetooth adapter in device manager instead of rebooting. Again, I do not recommend programming over bluetooth. The JY-MCU already provides an easy to use serial connection but was not meant to program.
Also when I said "up arrow (on either RX or TX)", I said "either" because I could not remember which one it was. The pins don't do the same thing.
You seem to know what you are doing so I trust you can troubleshoot.
