I am using an Encoder motor and PID logic to control its position like a servo motor. The code attached below is working fine.
I want to save the value of the pos
variable in the code, so that when I restart the program next time, I can retrieve that saved value. Currently, its value is zero when i start the program. How can I do this?
I want that the motor should be set at a certain position whenever i start the arduino UNO. So for eg if it was left at 240degrees the last time i ran the program, I restart the Arduino and the motor turns back at zero position. This I can only do If i have the last pos
value saved and turn the motor accordingly.
Or is there any other method for this?
This is the motor I'm using: https://www.aliexpress.com/item/32612296812.html
I'm using it with L298N Motor Driver
#define ENCA 2
#define ENCB 3
#define PWM 5
#define IN2 6
#define IN1 7
int turns = 0;
int target;
int pos;
long prevT = 0;
float eprev = 0;
float eintegral = 0;
pinMode(ENCA,INPUT);
pinMode(ENCB,INPUT);
attachInterrupt(digitalPinToInterrupt(ENCA),readEncoder,RISING);
Serial.println("target pos");
if (Serial.available() >0) {
int x = Serial.parseInt();
target = x;
//target = 250*sin(prevT/1e6);
// PID constants
float kp = 1;
float kd = 0.026;
float ki = 0.02;
// time difference
long currT = micros();
float deltaT = ((float) (currT - prevT))/( 1.0e6 );
prevT = currT;
// error
int e = pos-target;
// derivative
float dedt = (e-eprev)/(deltaT);
// integral
eintegral = eintegral + e*deltaT;
// control signal
float u = kp*e + kd*dedt + ki*eintegral;
Serial.print(u);
Serial.print(" ");
// motor power
float pwr = fabs(u);
if( pwr > 255 ){
pwr = 255;
// motor direction
int dir = 1;
if(u<0){
dir = -1;
// signal the motor
setMotor(dir,pwr,PWM,IN1,IN2);
// store previous error
eprev = e;
Serial.print(target);
Serial.print(" ");
Serial.println(pos);
void setMotor(int dir, int pwmVal, int pwm, int in1, int in2){
analogWrite(pwm,pwmVal);
if(dir == 1){
digitalWrite(in1,HIGH);
digitalWrite(in2,LOW);
else if(dir == -1){
digitalWrite(in1,LOW);
digitalWrite(in2,HIGH);
else{
void readEncoder(){
int b = digitalRead(ENCB);
if(b > 0){
pos++;
else{
pos--;
