Hello guys, I'm currently working on an RFID project, I have an RTC module, I need to get the times when the RFID MFRC522 detects that a tag is present, and the time when I get the tag of the reader.
show sketch
This one for the RTC
#include <ThreeWire.h>
#include <RtcDS1302.h>
ThreeWire myWire(27,26,25); // IO, SCLK, CE
RtcDS1302<ThreeWire> Rtc(myWire);
String currentTime;
void setup ()
Rtc.Begin();
void loop ()
RtcDateTime now = Rtc.GetDateTime();
printDateTime(now);
if (!now.IsValid())
// Common Causes:
// 1) the battery on the device is low or even missing and the power line was disconnected
Serial.println("RTC lost confidence in the DateTime!");
delay(2000); // ten seconds
#define countof(a) (sizeof(a) / sizeof(a[0]))
void printDateTime(const RtcDateTime& dt)
char datestring[20];
snprintf_P(datestring,
countof(datestring),
PSTR("%02u:%02u:%02u"),
dt.Hour(),
dt.Minute(),
dt.Second() );
Serial.print(datestring);
and this for reading the tag
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN 22 // Configurable, see typical pin layout above
#define SS_PIN 5 // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance
MFRC522::StatusCode status;
MFRC522::MIFARE_Key key;
byte buffer1[18];
byte buffer2[18];
byte buffer3[18];
String getTaskTypeID;
//byte len = sizeof(buffer);
byte len = 34;
Serial.begin(9600); // Initialize serial communications with the PC
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
readTask();
void readTask(){
// Prepare key - all keys are set to FFFFFFFFFFFFh at chip delivery from the factory.
for (byte i = 0; i < 6; i++) key.keyByte[i] = 0xFF;
// Reset the loop if no new card present on the sensor/reader. This saves the entire process when idle.
if ( ! mfrc522.PICC_IsNewCardPresent()) {
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial()) {
return;
Serial.println(F("**Card Detected:**"));
//------------------------------------------- GET TASK ID
Serial.print(F("Task ID: "));
readBlock(buffer1,4);
//getTaskId = String((char*)buffer1);
//Serial.println(getTaskId);
//---------------------------------------- GET TASK TYPE ID
Serial.print(F("\nTask Type ID: "));
readBlock(buffer2,5);
getTaskTypeID = String((char*)buffer2);
//Serial.println(getTaskName);
//---------------------------------------- GET TASK DATA: NB TOURS
Serial.print(F("\nTask Delai: "));
readBlock(buffer3,6);
//getTaskDelai = String((char*)buffer3);
//Serial.println(getTaskDelai);
Serial.println(F("\n**End Reading**\n"));
delay(1000); //change value if you want to read cards faster
mfrc522.PICC_HaltA();
mfrc522.PCD_StopCrypto1();
void readBlock(byte *buffer,byte block){
status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, block, &key, &(mfrc522.uid)); //line 834 of MFRC522.cpp file
if (status != MFRC522::STATUS_OK) {
Serial.print(F("Authentication failed: "));
Serial.println(mfrc522.GetStatusCodeName(status));
return;
status = mfrc522.MIFARE_Read(block, buffer, &len);
Serial.print(F("Reading failed: "));
return;
//PRINT ...
for (uint8_t i = 0; i < 16; i++){
Serial.write(buffer[i]);
So you have 2 pieces of code that someone else has written, and your assignment is to combine them?
I got this code from the library, I'm trying to combine them and get the time when I put the tag on the reader and the time the tag leave the reader
So you've tried?... great! Please post your attempt.
