and I connect to scale by IC MAX232CPE.
I use 2 pieces of rs232 because I want to recive wieght and send to thermal Printer
I use the frist rs232 to connect to scale.
pin2 rx pin3tx pin5 GNd link to image.
out put is a language I do not know. It is a square box.
<Arduino is ready>
Char received square box
ardiono
Gray wire 5V to max232cpe (on power pin zone)
Black wire GND to max232cpe (on power pin zone)
yellow wire tx to max232cpe (on communication pin zone)
Green wire rx to max232cpe (on communication pin zone)
yellow2 wire tx to max232cpe (on communication pin zone)
Green2 wire rx to max232cpe (on communication pin zone)
Gray wire2 Gnd to 7segment (on digital pin zone)
White wire 5v to 7segment (on digital pin zone)
Sorry, I had a mistake in the extra code I asked you to insert.
Change
Serial.write( (byte) rc); //NEW
to
Serial.print( (byte) rc); //NEW
and try again. It should print the ASCII values of the characters being received.
I appreciate that you have taken a lot of trouble to post pictures but I'm afraid it was all in vain as they do not tell what I need to know. A photo of a simple pencil drawing showing how everything is connected is all that is required.
In your Reply #23 you showed a few lines starting with Char received. You should also be getting those lines with the code in Repy #26 if the ONLY change between the two programs was the one I recommended in Reply #25
Back in Reply #17 you were using Serial1 to talk to the scale but in Reply #23 it is Serial2. Did you change the pins the scale is connected to? Or is it still connected to Serial1?
Your diagram in Reply #26 is a step in the right direction but you need to develop it to show each individual wire and which pin it is connected to.
When i use serial1 i use tx1 rx1 pin and When i use serial2 i use tx2 rx2 pin .
Output in DEC
Serial.print( rc,DEC);
<Arduino is ready>
Char received 85
Char received 83
Char received -84
Char received 45
Char received 48
Char received 48
Char received 48
Char received 48
Char received 48
Char received 46
Char received 54
Char received -72
Char received -96
Char received -96
Char received -25
Char received -115
Char received 10
This just in ... US⸮-00000.6⸮⸮⸮⸮
Out put in byte
<Arduino is ready>
Char received S
Char received ⸮
Char received ⸮
Char received -
Char received 0
Char received 0
Char received 0
Char received 0
Char received 0
Char received .
Char received 5
Char received 6
Char received ⸮
Char received ⸮
Char received ⸮
Char received ⸮
Char received
This just in ... SԬ-00000.56⸮⸮⸮
It looks like you have made another change to your program. Please post the full program (or programs) that produced the two outputs that you have shown in Reply #28. I can't see your PC screen from here.
scale monitor show 91.35
Some numbers is Unknown language resemble box
example
num 1 is ⸮
num 2 is ⸮
num 4 is ⸮
num 7 is ⸮
num 8 is ⸮
num 0 can show
num 3 can show
num 5 can show
num 6 can show
num 9 can show
out put Serial monitor is
This just in ... SԬ+0009⸮.35⸮⸮⸮
How am I supposed to know what is going on as you have not posted a proper diagram for the circuit either before or after this change.
I am finding it very frustrating trying to help with your project. You seem to be jumping around all over the place rather than taking a methodical step-by-step approach.
If I can get time I will try the code you posted in Reply #30 and DO NOT make any more changes to it.
