How to give a C++ variable name to an asm statement?
Hello,
I am trying to do something like this:
asm volatile("sts %0, r0" : "+M" (PCintPort::curr) );
But the error I'm getting is:
error: impossible constraint in 'asm'
I find that it's easy to do a c-style asm statment, like:
uint8_t myvariable;
asm volatile("sts myvariable, r0");
But using a static C++ class variable is confounding me. The variable is declared thus:
class PCintPort {
public:
    static  uint8_t curr;
Thanks.
GreyGnome:
That syntax is nothing like your other working example. If (PCintPort::curr) is intended to be an input operand, shouldn't it be quoted? And probably separated by a colon from "+M" if that is intended to be an output operand.
If you aren't sure of the syntax of the assembler, I suggest you disassemble a bit of C++ that includes a reference to the type of variable you're after, and see what you get.
Are you sure you know what you're doing? I think it's m not M but I am not sure. With inline asm the best technique is to search Google for as many examples as you can find of other people using it as it is not very well documented, the only way is to find someone elses example that works and copy it. Then disassemble the elf file and make sure it looks like it has done what you expect!
PeterH:
GreyGnome:
I did that. I got "0x0160" which is the memory location of the variable. Of course, that will change as soon as I change my sketch... :frowning: So I need to refer to it symbolically in my asm statement, which indeed I'm unaware of the syntax. Google searching proved fruitless to me.
I was right, it is m, here's the answer: Simple Constraints - Using the GNU Compiler Collection (GCC)
Also I found this: www.pek.nu/pekproj/proj/el/avrex/tiny2313_uart_firmware_update.c That code uses sts in inline assembler towards the end, you might be able to learn the syntax off it.
Also under some circumstances you need to clobber memory (usually when the function later on reads the variable you wrote to)
Thanks! That's it! The following statement is what I wanted:
asm volatile("sts %0, r0" : "+m" (PCintPort::curr) :: );
and it generated the following assembly language code:
4be: 00 92 60 01 sts 0x0160, r0
Thanks again. It finally compiles without complaining. :slight_smile:
