Is there a module that can give the Wi-Fi direct capabilities?
The closest I could find is the ESP8266, but unfortunately that only acts as a soft access point and is not using the Wi-Fi Direct protocol (unfortunately this won't fit my needs)
Thanks in advance!
From Wikipedia:
Wi-Fi Direct, initially called Wi-Fi P2P, is a Wi-Fi standard enabling devices to easily connect with each other without requiring a wireless access point.[1] It is usable for everything from internet browsing to file transfer,[2][3] and to communicate with more than one device simultaneously at typical Wi-Fi speeds.[4] One advantage of Wi-Fi Direct is the ability to connect devices even if they are from different manufacturers. Only one of the Wi-Fi devices needs to be compliant with Wi-Fi Direct to establish a peer-to-peer connection that transfers data directly between them with greatly reduced setup
ScotleCyphez:
The closest I could find is the ESP8266, but unfortunately that only acts as a soft access point and is not using the Wi-Fi Direct protocol (unfortunately this won’t fit my needs)
Thanks in advance!
Arduino Yun/compatible with latest OS Chaos Calmer does support 802.11s. 802.11s could connect end-user devices without infrastructure
- P2P (Wi-Fi Direct)
- IBSS (ad-hoc)
No official Chaos Calmer support arduino yun yet! compile it yourself.
