Hello,
I have an assignement that I'm struggeling with :
I need to use a Pololu Zumo 32U4, and a color sensor made from LDR + RGB LED (schematic attached)
I'm able to successfully fetch the RGB codes (see the code)
Code (too long to fit on the post message)
But I actually need to recover the color that that RGB code signify
I have a checkerboard with 6 colors which are [Black, White, Red, Green, Blue and Yellow], and the robot will need to make a specific action after having scanned the color
Black and White will not be an issue though as Black report as ~{0,0,0} and White ~{255,255,255} due to the calculation method used
But the issue here is the other 4 colors, especially Yellow
I was thinking about a percentage-based method but the yellow will effectively not work as it will only use the three primary color and I couldn't find the minimal percentage of Red and Green needed for that color to be actually Yellow
If someone had an idea that would be awsome
Thanks in advance
