How to handle parasites in signals.
Hello, I have built the following circuit.
74LS125 is a quad- tristate buffer. I am using it for turning on and of the connections between servo and my servo controller for irrelevant reasons. Note that that IC is low-active so when the enable pin is connected to ground, it is allowing current to pass.
Anyway, I am positive that two servo pwm signals are intertwining with each other. Sometimes, not always, servo 2 moves when I am moving only servo 1. I really want to prevent that.
Some other information:
I am prototyping using a breadboard.
I am using single core assembly cable for connections and yes those cables are pretty located close but isolated by rubber cover.
I am using standard jumper cables for external connections.
You can find the datasheet for IC in this link.
Any idea why this is happening?
Pin 7 should be grounded.
Of course pin 7 is grounded. I didn't draw it to complicate the diagram. As you may have well understood from my question, I am not having trouble using the IC. I will draw more accurately next time.
isaturk:
Generally; not a good idea to ommit connections in schematics ....................
How can anyone know when you do this on purpose ?
Inadequate servo power supplies, such as misguided attempts to use the Arduino 5V output, account for at least 95% of the servo problems reported on this forum.
Post ALL the details of your setup, not just those that you think are relevant. Include the specs of the Arduino and servo power supplies, and show all ground connections.
What do you think the 74LS125 does in your circuit, and what is it supposed to do?
...and what parasites?
I suspect that "parasitic" is meant, and that capacitance between connecting wires, breadboard tracks, etc. is the only reason that the circuit even seems to work.
Otherwise, the circuit makes no sense to me.
jremington:
To me, it looks like an attempt to switch the servo ground on and off. It should work for really low currents but I guess a servo load is usually too much. That is a huge assumption as the connection at the servo is not labeled.
Why I use 74LS125 is really irrelevant but you can get an understanding of it by looking at this schematic
Yes, the problem was not parasitics. It was a power problem. Which raises the question of how can it be solved.
I connected just one servo to an external 5V adaptor and it worked fine. However, to the best of my observations, when I use multiple servos or use one extensively; voltage readings decrease all the way up to 4V. I tried using ardunio's 5v, external adaptor and some batteries but the result is the same.
This is just one part of my circuit, there are some other parts vital for me that I can let these type of voltage dropdowns. Is there a way to regulate and achieve a stable 5V supply.
If A4 is grounded, how will Y4 ever be HIGH?
isaturk:
Yes, there are many ways. Linear regulators, switching regulators. Bare boards, modules, wall adapters...
In all cases, the load must not exceed the capacity of the supply. No doubt that is what has happened.
Good luck with your project.
You are right, and it is not even interesting.
You need a power supply that can support more current.
Generally one amp per servo is recommended.
We could suggest better if we knew the servo type.
If you used the '125 to control the servo control signal instead of it's power or Gnd you'd probably have better luck,
I am using 125 to manage servo signals, not their power input.
My servo is sg90. I will have 4 of them on board. In this case, will 7805 voltage regulator be enough which supports up to 1 v according to its datasheet. I have a 11.7V lipo battery which will support power to the whole circuit
