I am using Ultrasonic sensor, LED, and buzzer in my circuit. However, I need the LED to stay on for like 10 seconds or more.
Here is my code
const int trigPin = 9;
const int echoPin = 10;
const int buzzer = 11;
const int ledPin = 13;
long duration;
int distance;
int safetyDistance;
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(buzzer, OUTPUT);
pinMode(ledPin, OUTPUT);
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = duration * 0.034 / 2;
safetyDistance = distance;
if (safetyDistance <= 5) {
digitalWrite(buzzer, HIGH);
digitalWrite(ledPin, HIGH);
else {
digitalWrite(buzzer, LOW);
digitalWrite(ledPin, LOW);
Serial.print("Distance: ");
Serial.println(distance);
If you don't mind the program doing nothing for 10 seconds then delay(10000);
will do what you want
If you need to do other things during the period then delay() is not the way to do it. Take a look at Using millis() for timing. A beginners guide, Several things at the same time and the BlinkWithoutDelay example in the IDE
Hello
I ´ve add a timer to your sketch.
The sketch is untestet, but well done
enum {Led};
const unsigned long Duration {10000};
struct TIMER {
unsigned long timeStamp;
unsigned long duration;
} timer[] {
{0,Duration},
long duration;
int distance;
int safetyDistance;
void startTimer (TIMER &timer) {
timer.timeStamp= millis();
void stopTimer(TIMER &timer) {
timer.timeStamp= 0;
enum {NoEvent,Event};
bool eventTimer(TIMER &timer) {
return (( millis() - timer.timeStamp >= timer.duration && timer.timeStamp)?Event:NoEvent);
startTimer(timer[Led]);
else {
if (eventTimer(timer[Led])) digitalWrite(ledPin, LOW),stopTimer(timer[Led]);
It worked perfectly. Thank you!
system
Closed
#7
