Hi, i am new with the programming, i am trying with the program below however the LED light cannot hold even PIR continue active. It still turn on and off follow the delay timer. The desire result is LED should be continue on as long as motion is still actively detected by PIR. Appreciate your help, thanks
// https://forum.arduino.cc/t/how-to-delay-using-millis/1142938
// https://wokwi.com/projects/368911815269434369
// version 4. remove anydebouncing
const byte buttonPin = 2;
const byte ledPin = 3;
const unsigned long actionDelay = 3500; // action 3.5 seconds for testing - life too short
Serial.println("\nWake up!\n");
pinMode (buttonPin, INPUT_PULLUP);
pinMode (ledPin, OUTPUT);
digitalWrite(ledPin, LOW);
static unsigned long startTime; // time at action
unsigned long now = millis(); // fancier 'currentMillis' ooh!
int buttonState = !digitalRead(buttonPin); // button pulled up!
// when the button is pressed, reset the timer, turn ON the LED
if (buttonState == HIGH) {
startTime = now;
digitalWrite(ledPin, HIGH);
// when (if!) the timer expires, turn OFF the LED
if (now - startTime >= actionDelay) {
