# How to identify Ground / Data / Voltage supply?
**URL:** <https://forum.arduino.cc/t/how-to-identify-ground-data-voltage-supply/173967>\
**Category:** General Electronics\
**Created:** [July 18, 2013, 11:58am UTC](https://forum.arduino.cc/t/how-to-identify-ground-data-voltage-supply/173967 "2013-07-18T11:58:46Z")\
**Posts on this page:** 13\
**Page:** 1
<div class="post-metadata">
**Post date:** [July 18, 2013, 11:58am UTC](https://forum.arduino.cc/t/how-to-identify-ground-data-voltage-supply/173967/1 "2013-07-18T11:58:46Z")
</div>
I bought an IR receiver and IR transmitter:
Receiver:
 ![](https://europe1.discourse-cdn.com/arduino/original/4X/6/b/e/6bee7d23430af4df74ddce9bb7088da6792244f6.jpeg)
Transmitter:
 ![](https://europe1.discourse-cdn.com/arduino/original/4X/a/1/f/a1f06a45af06cdf1e0baca17c54b630c82e1dfab.jpeg)
How can I find out what each of the three pins are? It isn't written anywhere I can see. There's only written an "S", "-", "R1" and "Keyes".
Your help is much appreciated 😃
Thanks!
**Post date:** [July 18, 2013, 12:00pm UTC](https://forum.arduino.cc/t/how-to-identify-ground-data-voltage-supply/173967/2 "2013-07-18T12:00:55Z")
</div>
I'm afraid of damaging the components if I do it wrong. Is there any risk of doing so (apart from killing up the IR LED using no resistor)?
**Post date:** [July 18, 2013, 1:42pm UTC](https://forum.arduino.cc/t/how-to-identify-ground-data-voltage-supply/173967/3 "2013-07-18T13:42:06Z")
</div>
Ok, so I found the datasheet for the IR receiver 🙂
> **[TSOP1838 Datasheet(PDF) - Vishay Siliconix](https://www.alldatasheet.com/datasheet-pdf/pdf/26604/VISHAY/TSOP1838.html)**
> Photo Modules for PCM Remote Control Systems, TSOP1838 Datasheet
I'll be interested in the datasheet for the IR LED too, to know how small a resistor I can use (for maximum IR lighht emission strength).
**Author:** ![Grumpy\_Mike](https://dub1.discourse-cdn.com/arduino/user_avatar/forum.arduino.cc/grumpy_mike/32/213521_2.png) [@Grumpy\_Mike](https://forum.arduino.cc/u/Grumpy_Mike)\
**Post date:** [July 18, 2013, 2:06pm UTC](https://forum.arduino.cc/t/how-to-identify-ground-data-voltage-supply/173967/4 "2013-07-18T14:06:36Z")
</div>
That is likely to depend on how you drive it. An arduino should not be asked to deliver more than 40mA and most IR LEDs can take more than this.
Typically you can use a 33R resistor if you drive it with a transistor.
**Post date:** [July 18, 2013, 3:20pm UTC](https://forum.arduino.cc/t/how-to-identify-ground-data-voltage-supply/173967/5 "2013-07-18T15:20:23Z")
</div>
Thanks for the heads up! I'm driving it with the Arduino. 🙂
Hmmm. I don't understand why the IR Transmitter is composed of an IR LED with 2 pins connected to some other and seemingly meaningless component with 3 output pins.
**Post date:** [July 18, 2013, 4:25pm UTC](https://forum.arduino.cc/t/how-to-identify-ground-data-voltage-supply/173967/6 "2013-07-18T16:25:47Z")
</div>
Could be a transistor already on the board.
Any chance of a photo of the other side.
**Post date:** [July 18, 2013, 4:42pm UTC](https://forum.arduino.cc/t/how-to-identify-ground-data-voltage-supply/173967/7 "2013-07-18T16:42:19Z")
</div>
Here is the other side:
 ![](https://europe1.discourse-cdn.com/arduino/original/4X/6/0/5/605a08ac4092b2c777fd3a14ffa5ddf8fca1b6e3.jpeg)
There are two little "metal squares", one above each of the two right-most pins. Perhaps that is something. I'm still trying to find this at [alldatasheet.com](http://alldatasheet.com). No luck yet, but the search continues 🙂
**Author:** ![MarkT](https://avatars.discourse-cdn.com/v4/letter/m/c89c15/32.png) [@MarkT](https://forum.arduino.cc/u/MarkT)\
**Post date:** [July 18, 2013, 5:28pm UTC](https://forum.arduino.cc/t/how-to-identify-ground-data-voltage-supply/173967/8 "2013-07-18T17:28:33Z")
</div>
This is standard servo connector layout. - means ground, + is supply, S is signal.
Note that the solder pads are round except for one that is square - that means its pin number 1,
should you have a schematic to compare to.
**Post date:** [July 18, 2013, 6:49pm UTC](https://forum.arduino.cc/t/how-to-identify-ground-data-voltage-supply/173967/9 "2013-07-18T18:49:59Z")
</div>
Thanks alot! 😃 I'm going to write these things down for further reference 🙂
I'm building a radio-to-infrared interface, so I can control my devices from a greater distance 🙂 If it works well I will maybe to a Web-to-infrared interface as well 🙂
**Post date:** [July 18, 2013, 6:56pm UTC](https://forum.arduino.cc/t/how-to-identify-ground-data-voltage-supply/173967/10 "2013-07-18T18:56:06Z")
</div>
Have you tried googling "Keyes IR emitter" and/or "Keyes IR receiver"?
I found a few tutorials, info, and this photo with pin connections.
![image.jpg](https://europe1.discourse-cdn.com/arduino/original/4X/2/4/8/248f5506f6fadfa940b6784978a5f2fc5652e359.jpeg)
**Author:** ![Zapro](https://dub1.discourse-cdn.com/arduino/user_avatar/forum.arduino.cc/zapro/32/214413_2.png) [@Zapro](https://forum.arduino.cc/u/Zapro)\
**Post date:** [July 18, 2013, 9:36pm UTC](https://forum.arduino.cc/t/how-to-identify-ground-data-voltage-supply/173967/11 "2013-07-18T21:36:47Z")
</div>
There is a reason for that IR-emitter board to look a bit strange - it's meant for a pushbutton with pullup resistor - it's simply being re-purposed as a carrier for the IR LED.
**Post date:** [July 19, 2013, 5:56am UTC](https://forum.arduino.cc/t/how-to-identify-ground-data-voltage-supply/173967/12 "2013-07-19T05:56:12Z")
</div>
> thecoon:
I can't see this component from your photograph. In fact I can't see any components at all.
I would connect it up with a 220R seriese resistor to 5V and ground and measure the voltage across the LED. Look at the LED through the electronic viewfinder of a camera to see which way round it lights. Then drive it with a transistor and work out the resistor to give you 80mA current through it.
**Post date:** [May 6, 2021, 1:23am UTC](https://forum.arduino.cc/t/how-to-identify-ground-data-voltage-supply/173967/13 "2021-05-06T01:23:17Z")
</div>
Closed on May 6, 2021, 1:23am UTC
