How to identifythe MPU 6050 3-axis gyroscope and accelerometer's angle?
How do you identify the specific angle with the values given in my code?
#include "Wire.h"
#include "Arduino.h"
#include "SoftwareSerial.h"
const int MPU_ADDR=0x68; // I2C address of the MPU-6050. If AD0 pin is set to HIGH, the I2C address will be 0x69.
int16_t accelerometer_x, accelerometer_y, accelerometer_z; // variables for accelerometer raw data
int16_t gyro_x, gyro_y, gyro_z; // variables for gyro raw data
int16_t temperature; // variables for temperature data
char tmp_str[7]; // temporary variable used in convert function
char* convert_int16_to_str(int16_t i) { // converts int16 to string. Moreover, resulting strings will have the same length in the debug monitor.
  sprintf(tmp_str, "%6d", i);
  return tmp_str;
  Wire.begin();
  Wire.beginTransmission(MPU_ADDR); // Begins a transmission to the I2C slave (GY-521 board)
  Wire.write(0x6B); // PWR_MGMT_1 register
  Wire.write(0); // set to zero (wakes up the MPU-6050)
  Wire.endTransmission(true);
  Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H) [MPU-6000 and MPU-6050 Register Map and Descriptions Revision 4.2, p.40]
  Wire.endTransmission(false); // the parameter indicates that the Arduino will send a restart. As a result, the connection is kept active.
  Wire.requestFrom(MPU_ADDR, 7*2, true); // request a total of 7*2=14 registers
  // "Wire.read()<<8 | Wire.read();" means two registers are read and stored in the same variable
  accelerometer_x = Wire.read()<<8 | Wire.read(); // reading registers: 0x3B (ACCEL_XOUT_H) and 0x3C (ACCEL_XOUT_L)
  accelerometer_y = Wire.read()<<8 | Wire.read(); // reading registers: 0x3D (ACCEL_YOUT_H) and 0x3E (ACCEL_YOUT_L)
  accelerometer_z = Wire.read()<<8 | Wire.read(); // reading registers: 0x3F (ACCEL_ZOUT_H) and 0x40 (ACCEL_ZOUT_L)
  temperature = Wire.read()<<8 | Wire.read(); // reading registers: 0x41 (TEMP_OUT_H) and 0x42 (TEMP_OUT_L)
  gyro_x = Wire.read()<<8 | Wire.read(); // reading registers: 0x43 (GYRO_XOUT_H) and 0x44 (GYRO_XOUT_L)
  gyro_y = Wire.read()<<8 | Wire.read(); // reading registers: 0x45 (GYRO_YOUT_H) and 0x46 (GYRO_YOUT_L)
  gyro_z = Wire.read()<<8 | Wire.read(); // reading registers: 0x47 (GYRO_ZOUT_H) and 0x48 (GYRO_ZOUT_L)
  if (accelerometer_x < 1000 && accelerometer_y < -8000) {
    Serial.print('1');
  else if (accelerometer_x < 1000 && accelerometer_y > 8000){
    Serial.print('2');
  else if (accelerometer_x > 6000 && accelerometer_y < 5000) {
    Serial.print('3');
  else if (accelerometer_x < -8000 && accelerometer_y < 600) {
    Serial.print('4');
  Serial.print('0');
  delay(2000);
With your posted code, you don't.
However, after doing the scale factor thing and the apply drift rate thing you can use a formula to get angles.
Here you can get the angle from just the acceleros
       roll = atan2f( get_aX(), sqrtf( (get_aY() * get_aY()) + (get_aZ() * get_aZ())) );
        pitch = atan2f( get_aY(), sqrtf( (get_aX() * get_aX()) + (get_aZ() * get_aZ())) );
But in short order you'll see that this angles produced are noisy. So you'll consider adding in a filter, internet search on "complementary filter arduino." If you want to go even deeper there is the onehorse | Mbed[/url.
What do you mean by the scale factor thing and drift rate thing? And how do you get the scale factor thing?
