I am doing a sketch using an ESP8266 as a wifi server, I need to send a character string to the Client, for this I am using this piece of code:
char sbuf[] = "Hello world!\n\r";
size_t len = strlen(sbuf);
for (i = 0; i < MAXCLIENTS; i++) {
if (serverClients[i] && serverClients[i].connected()) {
serverClients[i].write((char*) &sbuf, len);
delay(1);
It works OK, the client can receive the characters
but now I want to make a function to call it the times I need it, this is the function code:
void sendDataToClient( char *sbuf[]) {
delay(1);
That's I'm calling the function:
char bufferMSGtoClient[] = "Hello world!\n\r";
sendDataToClient(bufferMSGtoClient)
But it doesn't work, the client does not receive anything, someone can tell me what is my error?
Note, I am completely out of my pay scale here, but try this:
void sendDataToClient( const char *sbuf) {
size_t len = sizeof(sbuf);
delay(1);
size_t len = sizeof(sbuf); <- I don't think this is doing what you think its doing. I'm pretty sure its just going to give you the size of a char. Could be wrong though..
int len = strLen(sbuf); <- may work better. Giving you the number of chars in the string. Not including the trailing '\0'.
-jim lee
SteveMann and jimLee,
I already made the change of the sizeof by strlen and *sbuf, now I can already get the number of characters but still I still the client cannot receive the characters
Well, can't help because, I've no idea what..
serverClients_.write((char*) &sbuf, len);_
serverClients write wants.
Well, I'll take a guess..
possibly?..
serverClients_.write((char*) &(sbuf[0]), len+1); // +1 in case you forgot the '\0'_
-jim lee
jimLee,
using this code:
delay(1);
I have no problems, it works OK, the client receives the string, the problem occurs when I try to implement the function to call it when I need it
delay(1);
I'd write it..
void sendDataToClient( char* sbuf) {
Also, if your thing expects a c string..
size_t len = strlen(sbuf)+1;
IF its only expecting the chars.. then don't bother on that.
-jim lee
You are passing a character pointer OR an array of characters. You are telling the function to expect an array of character pointers. I'm surprised you didn't get a compiler warning.
In Preferences, set compiler warnings to "All". Look at the warnings that show up in the text box below your sketch when you do a compile. Often they will point out mistaken assumptions.
