I am having a MS4525DO sensor and want to run it for airspeed data on arduino
I found the code that based on ardupilot software
Of course this code can not be run directly
how can I revised them and get the airspeed data from arduino without the ardupilot software?
#include "AP_Airspeed_MS4525.h"
#include <AP_Common/AP_Common.h>
#include <AP_HAL/AP_HAL.h>
#include <AP_HAL/I2CDevice.h>
#include <AP_Math/AP_Math.h>
#include <stdio.h>
#include <utility>
extern const AP_HAL::HAL &hal;
#define MS4525D0_I2C_ADDR 0x28
AP_Airspeed_MS4525::AP_Airspeed_MS4525(AP_Airspeed &_frontend, uint8_t _instance) :
AP_Airspeed_Backend(_frontend, _instance)
// probe and initialise the sensor
bool AP_Airspeed_MS4525::init()
const struct {
uint8_t bus;
uint8_t addr;
} addresses[] = {
{ 1, MS4525D0_I2C_ADDR },
{ 0, MS4525D0_I2C_ADDR },
{ 2, MS4525D0_I2C_ADDR },
bool found = false;
for (uint8_t i=0; i<ARRAY_SIZE(addresses); i++) {
_dev = hal.i2c_mgr->get_device(addresses[i].bus, addresses[i].addr);
if (!_dev) {
continue;
WITH_SEMAPHORE(_dev->get_semaphore());
// lots of retries during probe
_dev->set_retries(10);
_measure();
hal.scheduler->delay(10);
_collect();
found = (_last_sample_time_ms != 0);
if (found) {
printf("MS4525: Found sensor on bus %u address 0x%02x\n", addresses[i].bus, addresses[i].addr);
if (!found) {
printf("MS4525: no sensor found\n");
return false;
// drop to 2 retries for runtime
_dev->set_retries(2);
_dev->register_periodic_callback(20000,
FUNCTOR_BIND_MEMBER(&AP_Airspeed_MS4525::_timer, void));
return true;
// start a measurement
void AP_Airspeed_MS4525::_measure()
_measurement_started_ms = 0;
uint8_t cmd = 0;
if (_dev->transfer(&cmd, 1, nullptr, 0)) {
_measurement_started_ms = AP_HAL::millis();
this equation is an inversion of the equation in the
pressure transfer function figure on page 4 of the datasheet
We negate the result so that positive differential pressures
are generated when the bottom port is used as the static
port on the pitot and top port is used as the dynamic port
float AP_Airspeed_MS4525::_get_pressure(int16_t dp_raw) const
const float P_max = get_psi_range();
const float P_min = - P_max;
const float PSI_to_Pa = 6894.757f;
float diff_press_PSI = -((dp_raw - 0.1f*16383) * (P_max-P_min)/(0.8f*16383) + P_min);
float press = diff_press_PSI * PSI_to_Pa;
return press;
convert raw temperature to temperature in degrees C
float AP_Airspeed_MS4525::_get_temperature(int16_t dT_raw) const
float temp = ((200.0f * dT_raw) / 2047) - 50;
return temp;
// read the values from the sensor
void AP_Airspeed_MS4525::_collect()
uint8_t data[4];
uint8_t data2[4];
if (!_dev->transfer(nullptr, 0, data, sizeof(data))) {
return;
// reread the data, so we can attempt to detect bad inputs
if (!_dev->transfer(nullptr, 0, data2, sizeof(data2))) {
return;
uint8_t status = (data[0] & 0xC0) >> 6;
// only check the status on the first read, the second read is expected to be stale
if (status == 2 || status == 3) {
return;
int16_t dp_raw, dT_raw;
dp_raw = (data[0] << 8) + data[1];
dp_raw = 0x3FFF & dp_raw;
dT_raw = (data[2] << 8) + data[3];
dT_raw = (0xFFE0 & dT_raw) >> 5;
int16_t dp_raw2, dT_raw2;
dp_raw2 = (data2[0] << 8) + data2[1];
dp_raw2 = 0x3FFF & dp_raw2;
dT_raw2 = (data2[2] << 8) + data2[3];
dT_raw2 = (0xFFE0 & dT_raw2) >> 5;
// reject any values that are the absolute minimum or maximums these
// can happen due to gnd lifts or communication errors on the bus
if (dp_raw == 0x3FFF || dp_raw == 0 || dT_raw == 0x7FF || dT_raw == 0 ||
dp_raw2 == 0x3FFF || dp_raw2 == 0 || dT_raw2 == 0x7FF || dT_raw2 == 0) {
return;
// reject any double reads where the value has shifted in the upper more than
// 0xFF
if (abs(dp_raw - dp_raw2) > 0xFF || abs(dT_raw - dT_raw2) > 0xFF) {
return;
float press = _get_pressure(dp_raw);
float press2 = _get_pressure(dp_raw2);
float temp = _get_temperature(dT_raw);
float temp2 = _get_temperature(dT_raw2);
_voltage_correction(press, temp);
_voltage_correction(press2, temp2);
WITH_SEMAPHORE(sem);
_press_sum += press + press2;
_temp_sum += temp + temp2;
_press_count += 2;
_temp_count += 2;
_last_sample_time_ms = AP_HAL::millis();
correct for 5V rail voltage if the system_power ORB topic is
available
See http://uav.tridgell.net/MS4525/MS4525-offset.png for a graph of
offset versus voltage for 3 sensors
void AP_Airspeed_MS4525::_voltage_correction(float &diff_press_pa, float &temperature)
const float slope = 65.0f;
const float temp_slope = 0.887f;
apply a piecewise linear correction within range given by above graph
float voltage_diff = hal.analogin->board_voltage() - 5.0f;
voltage_diff = constrain_float(voltage_diff, -0.7f, 0.5f);
diff_press_pa -= voltage_diff * slope;
temperature -= voltage_diff * temp_slope;
// 50Hz timer
void AP_Airspeed_MS4525::_timer()
if (_measurement_started_ms == 0) {
_measure();
return;
if ((AP_HAL::millis() - _measurement_started_ms) > 10) {
_collect();
// start a new measurement
_measure();
// return the current differential_pressure in Pascal
bool AP_Airspeed_MS4525::get_differential_pressure(float &pressure)
if ((AP_HAL::millis() - _last_sample_time_ms) > 100) {
return false;
if (_press_count > 0) {
_pressure = _press_sum / _press_count;
_press_count = 0;
_press_sum = 0;
pressure = _pressure;
return true;
// return the current temperature in degrees C, if available
bool AP_Airspeed_MS4525::get_temperature(float &temperature)
return false;
if (_temp_count > 0) {
_temperature = _temp_sum / _temp_count;
_temp_count = 0;
_temp_sum = 0;
temperature = _temperature;
return true;
