How to implement Hardware flowcontrol between LoRa module and Arduino (ESP8266)?
Dear Gentlemen,
My project requires me to send a huge volume of data that comes in UART portencrypt it and send to LoRa module (max 10-15kBytes) through Software Serial and receive in on other end decrypt it and send through UART again. since LoRa is not designed to send such high volume I am forced to buffer the data in ESP8266 and send chunks of 512 bytes(which is the buffer size in Lora Module{EByte E32 868T30D}). I have been working on my code for more than 2 weeks now but I am not quiet successfull in implementing a working code. All i need is to send a large volume of data through LoRa to other end and receive it on other end and send the data at once when the whole volume is received. Can somebody help me with this I seeking for expert help
   ---------------------------------------------------- ESP8266 EByte 32 Lora Encryption Test ----------------------------------------------------
   Author: Mister.B
   Date: 10 May 2020
   Objective: To test AES256 ECB Encryption on LoRa Modules
   Third-Party ibraries used:
   1) aes256 - https://github.com/qistoph/ArduinoAES256
#include "aes256.h"
#include <SoftwareSerial.h>
//EByte E32 Pin Configuration
#define M0 D5
#define M1 D6
#define AUX D2 // AUX HIGH means BUSY LOW means READY
#define RX_Pin D3
#define TX_Pin D4
//BaudRate Selection
#define E32_BAUD 9600
#define SERIAL_BAUD 9600
//AES Parameters
#define BUFFER_SIZE 2048 //2kB buffer to store the values
#define BLOCK_SIZE 16
//Timeout selection
#define UART_SERIAL_TIMEOUT 5000
#define E32_SERIAL_TIMEOUT 5000
//Debug Selection
#define DEBUG_CONSOLE true
//Class Instances
aes256_context ctxt;
SoftwareSerial E32(RX_Pin, TX_Pin);
//#define E32 Serial
//======Global Variables Declaration======
uint8_t key[] = {
  0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07,
  0x08, 0x09, 0x0a, 0x0b, 0x0c, 0x0d, 0x0e, 0x0f,
  0x10, 0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17,
  0x18, 0x19, 0x1a, 0x1b, 0x1c, 0x1d, 0x1e, 0x1f
uint8_t data_buffer[BUFFER_SIZE] = {};
int i = 0, in_count = 0, out_count = 0;
unsigned long last_packet_arrival = 0;
//MACROS
#define ARRAY_SIZE(arr) ((sizeof(arr))/(sizeof(arr[0])))
#if DEBUG_CONSOLE == true
#define DUMP(str,i,buf,sz){Serial.println(str);\
    for(i=0;i<sz;++i){if(buf[i]<0x10)Serial.print('0');Serial.print(char(buf[i]),HEX);}\
    Serial.println();}
#else
#endif
  Serial.begin(SERIAL_BAUD);
  E32.begin(E32_BAUD);
  pinMode(M0, OUTPUT);
  pinMode(M1, OUTPUT);
  pinMode(AUX, INPUT);
     Setting Ebyte 32 in Normal Mode (M0=LOW and M1=LOW)
  digitalWrite(M0, LOW);
  digitalWrite(M1, LOW);
  DUMP("\nKey:", i, key, sizeof(key));
  aes256_init(&ctxt, key); // Send key for key scheduling
  int frame_count = 0;
  out_count = 0;
  in_count = 0;
  last_packet_arrival = millis();
     RECEIVE DATA FROM EBYTE E32 LoRa
  if (E32.available()) {
    out_count = 0;
    frame_count = (int)E32.read();
    while ((millis() - last_packet_arrival < E32_SERIAL_TIMEOUT) or (frame_count > out_count)) {
      out_count += E32.readBytes(data_buffer+out_count,58);
      if (out_count >= BUFFER_SIZE)Serial.printf("\n Input Buffer[%d] full :(", BUFFER_SIZE); break; //Prevent buffer overflow
    Serial.printf("\nFc:%d", frame_count);
    frame_count = 0;
    Serial.printf("\nReceiveCount:%d\n", out_count);
    DUMP("\nRecived Data:", i, data_buffer, out_count);
    for (int n = 0; n <= (out_count / BLOCK_SIZE); n += BLOCK_SIZE)aes256_decrypt_ecb(&ctxt, data_buffer + n);
    DUMP("\nDecrypted Data:", i, data_buffer, out_count);
    for (int i = 0; i < out_count; i++)Serial.print((char)data_buffer[i]); yield();
    memset(data_buffer, 0x00, BUFFER_SIZE);
    out_count = 0;
     RECEIVE DATA FROM UART Port
  if (Serial.available()) {
    in_count=0;
    while ((millis() - last_packet_arrival) < UART_SERIAL_TIMEOUT) {
      in_count += Serial.readBytes(data_buffer + in_count, 58);
      if (in_count >= BUFFER_SIZE)Serial.printf("\n Output Buffer[%d] full :(", BUFFER_SIZE); break; // Prevent buffer overflow
       Padding with zeros
    if (in_count < 58) { // if Serial data entered is smaller than 58
      for (int i = in_count; i < 58; i++)data_buffer[i] = 0x00;
    if (in_count > 58 && (in_count % 58 != 0)) { // if the Serial data is not multiple of 58 do padding with 0x00
      for (int i = in_count; i < in_count + (in_count % 58); i++)data_buffer[i] = 0x00;
    Serial.printf("\nSendCount:%d", in_count);
    DUMP("\nData Entered:", i, data_buffer, in_count);
    //for (int n = 0; n <= (in_count / BLOCK_SIZE); n += BLOCK_SIZE)aes256_encrypt_ecb(&ctxt, data_buffer + n); // Encrypting whole data by 16 byte blocks
    //DUMP("\nEncrypted Data:", i, data_buffer, in_count);
       Add the length number of 512 byte in data frame
    //uint8_t data_frame[BUFFER_SIZE + (BUFFER_SIZE % 58)] = {};
    //for (int i = 0; i <= BUFFER_SIZE; i++) data_frame[i + 1] = data_buffer[i];
    //data_frame[0] = (in_count / 58) + 1;
    //DUMP("\nSent Data:", i, data_frame, in_count + 1);
       Prevent buffer overflow in LoRa module using Hardware Flow control
    uint8_t buff[58] = {};
//    for (int i = 0; i < (in_count / 464)+1 ; i++) //divide the data buffer into 464 byte frames
//      for (int j = 464 * i; j < (464 * i) + 464; j += 58) { //divide the 464 byte frames into 58 byte frames
        byte* f_count=(in_count<58) ? in_count : (in_count / 58) + 1;
        E32.write(f_count,1);
        for (int j = 0 ; j < in_count ; j+=58){
        memcpy(buff, data_buffer + j, 58);
        aes256_encrypt_ecb(&ctxt,buff);
        DUMP("\nEncrypted Data:", i, buff, 58);
        while (digitalRead(AUX) == HIGH) yield(); // wait for the pin to get LOW
        if (digitalRead(AUX) == LOW) { //if the module is READY send
          E32.write(buff, 58);
//          E32.flush();
    in_count = 0;
    //memset(data_frame, 0x00, ARRAY_SIZE(data_frame));
E32-868T30D_Usermanual_EN_v1.6.pdf (1.19 MB)
Brinth:
Since LoRa is not designed to send such high volume
Like most all RF devices LoRa devices require that the data sent is in the form of a packet of data, in the case of LoRa the maximum packet size is 255 bytes.
If you want to send high volumes of data with a LoRa device then go ahead, its designed for it, you just need to split the data into 255byte chunks.
Your question is not LoRa specific the module you are using is a standard LoRa device, which is SPI based, with a processor in front of it, turning the device into a serial\UART one.
So the problem you face is really about how do you spilt the large amount of data into chunks and send it through a serial device.
@srnet Yes, Thats where I am facing the issue. yes it is possible to separate an array in to chunks of data by moving the pointer. but, eventhough I am getting garbled values on other end. I tried using the AUX pin as Input to ESP8266 to control the flow based on the AUX Pin state but the AUX pin stays low even after the first 512 bytes is sent to to module and returns high only 500ms after end of Transmission. Also I need a way to inform the receiving module to wait for the number of bytes to receive. Can you help me giving me an overview of how the function should be, Since I am a newbie I can't able to figure out a soultion
srnet:
Also are you sure it is 255 bytes for Ebyte E32 868T30D ?. bcoz as far as I know the user manual shows 512 bytes as buffer size. do you mean the PHY layer of LoRa can send 255 bytes at once?
Brinth:
Do you mean the PHY layer of LoRa can send 255 bytes at once?
Yes maximum packet size of the loRa device is 255 bytes.
How the processor on the Ebyte deals with data, I have no idea. It might well accept what it calls a 'packet' of whatever size it likes, but if its more than 255 bytes it will have to be split it up to actually transmit over the air.
srnet:
Got it @srnet. But can you show me a sample function to split n bytes of data (10-15kB max) into 512 bytes and send to the LoRa module without losing the packets and also informing the receiver about the number of bytes and let it wait and receive the pre informed number of bytes and reform the data sent on receiver end?
