Hi! I want to figure out how to have an ATTiny85 that is coded with Arduino, to play a song when push button is pressed. How it works is that it should have an LED that's on to signal that the push button is ready to be pressed, and once it's pushed, the LED will turn off and the song will begin playing. Then, the LED will turn on again after the song is complete. The problem is that the program uses interrupt timers (ISR), and I'm not sure how I can implement it into the loop function to work the same way.
/* Digital Music Box v2
David Johnson-Davies - www.technoblogy.com - 16th March 2016
ATtiny85 @ 16 MHz (internal PLL; 4.3 V BOD)
CC BY 4.0
Licensed under a Creative Commons Attribution 4.0 International license:
http://creativecommons.org/licenses/by/4.0/
int Scale[] = {
680, 721, 764, 809, 857, 908, 962, 1020, 1080, 1144, 1212, 1284,
1361, 1442, 1528, 1618, 1715, 1817, 1925, 2039, 2160, 2289, 2425, 2569,
2722, 2884, 3055, 3237, 3429, 3633, 3849, 4078 };
const int Channels = 4;
const int Tempo = 4; // 4 = 4 beats per second
const int Decay = 9; // Length of note decay; max 10
const int led = 7; // Set for pin 7 of ATTiny85
volatile unsigned int Acc[Channels];
volatile unsigned int Freq[Channels];
volatile unsigned int Amp[Channels];
// Play Happy Birthday
const uint32_t Tune[] PROGMEM = {
//_*_*__*_*_*__*_*__*_*_*__*_*__*_
//C D EF G A BC D EF G A BC D EF G
0b00000000000000000001000000000000,
0b10000000000000000000010000000000,
0b00000000000000000000000000000000,
0b00001001000000000001000000000000,
0b00000000000000000000000010000000,
0b00100000000000000000000100000000,
0b00000101000000000000000000000000,
0b00000101000000000001000000000000,
0b00000000000000000000000000100000,
0b10000000000000000000000010000000,
0b00001001000000000000000000000000,
0b10000000000000000000000000000001,
0b00100000000000000000000000001000,
0b00001000000000000000000010000000,
0b00000100000000000000000100000000,
0b00000000000000000000010000000000,
0b00000000000000000000000000000100,
0b00000001000000000000000000001000,
0b00000101000000000000000000100000,
0b10001001000000000000000010000000,
0xFF}; // End of tune
//Globals persist throughout tune
int TunePtr = 0, Chan = 0;
// Watchdog interrupt plays notes
ISR(WDT_vect) {
sei(); // Allow interrupts
WDTCR |= 1<<WDIE;
unsigned long Chord = pgm_read_dword(&Tune[TunePtr]);
if (Chord == 0xFF) return;
TunePtr++;
// Read the bits in Chord
for (int Note = 0; Note < 32; Note++) {
if ((Chord & 0x80000000) != 0) {
Freq[Chan] = Scale[Note];
Amp[Chan] = 1<<(Decay+5);
Chan = (Chan + 1) % Channels;
Chord = Chord<<1;
// Generate square waves on 4 channels
ISR(TIMER0_COMPA_vect) {
signed char Temp, Mask, Env, Note, Sum=0;
for (int c = 0; c < Channels; c++) {
Acc[c] = Acc[c] + Freq[c];
Amp[c] = Amp[c] - (Amp[c] != 0);
Temp = Acc[c] >> 8;
Mask = Temp >> 7;
Env = Amp[c] >> Decay;
Note = (Env ^ Mask) + (Mask & 1);
Sum = Sum + Note;
OCR1B = Sum + 128;
pinMode(2, INPUT_PULLUP); // Set pushbutton to pin 2 as a pullup resistor
pinMode(led, OUTPUT);
// Enable 64 MHz PLL and use as source for Timer1
PLLCSR = 1<<PCKE | 1<<PLLE;
// Set up Timer/Counter1 for PWM output
TIMSK = 0; // Timer interrupts OFF
TCCR1 = 1<<CS10; // 1:1 prescale
GTCCR = 1<<PWM1B | 2<<COM1B0; // PWM B, clear on match
OCR1B = 128;
DDRB = 1<<DDB4; // Enable PWM output on pin 4
// Set up Timer/Counter0 for 20kHz interrupt to output samples.
TCCR0A = 3<<WGM00; // Fast PWM
TCCR0B = 1<<WGM02 | 2<<CS00; // 1/8 prescale
OCR0A = 99; // Divide by 100
TIMSK = 1<<OCIE0A; // Enable compare match, disable overflow
// Set up Watchdog timer for 4 Hz interrupt for note output.
WDTCR = 1<<WDIE | Tempo<<WDP0; // 4 Hz interrupt
int buttonState = digitalRead(2);
if (buttonState == HIGH){
digitalWrite(led, HIGH);
digitalWrite(led, LOW);
// Code for song here
