Does not seem to be a way to reset the millis(); I believe this only occurs on board reset or reboot of sketch.
You are correct but there is no need.
Save the value of millis() when the timing period starts and determine that the timing period has elapsed by subtracting the start value from the current value returned by millis() and compare the result to the required period in milliseconds.
When that occurs take the required action(s) and save the value millis() again as the start of the next period.
Depending on the granularity needed, I would suggest doing what the log monitors do. They increment a faster counter, then at a point (before the int/long rolls over in C/C++), it increments a slower counter. So again, depending on your requirements, you could count off seconds until you incremented a minute counter. After 60 of those, the hour counter, and so on.
Also, most here (including me) will try to convince you to not use delays like this. The way you can deal with millis() rolling over and giving a negative time is to use a second variable that occasionally holds millis' value. In pseudo-code:
long timer, secs, mins, hours, days, ...;
setup() {
timer = millis();
loop() {
logTime(timer);
<Something that is checking, running or looping>
trigger = true; # condition triggered, like stopping or starting
if (trigger) {
<do something with a state variable, etc.
void logTime(long t) {
if (millis() - t) >= 1000) {
secs += 1;
secs = 0;
timer = millis();
if (secs >= 60) {
mins += 1;
secs = 0;
if (mins>= 60) {
hours += 1;
mins = 0;
if (hours >= 24) {
days += 1;
hours = 0;
if ...
And of course, a good RTC and disk storage would be invaluable. RTCs have all the time functions you need, and with a battery can stay pretty accurate even through loss of power. Again, a lot depends on your full list of requirements.
Data logging portion of sketch is already done and uses NTP time syncing. Only issue remaining is the elapsed time counter for runtime. I used a simulation of the runtime to develop the rest of the sketch; which uses functions from my "NTP_Time-synced_Web_Interface.ino" sketch.
Not having a good day; apologies for my poor timing editing. I was not aware a reply had been posted.
Techno500:
If you have access to a real-time clock, then why even bother with millis() ?
Presumably, you know the starting time: you've been logging it, right? And we know that you know what time it is now. So all you need to do to find the elapsed time is...
At this point, this isn't even an Arduino question. It's a common sense question. Let's say you're at a restaurant. You order your food at 11:40, and it doesn't arrive until 12:30. In your review of the restaurant, you complain that you had to wait for... how many minutes?
If you know how to do that calculation, well then, just have the Arduino do the same calculation!
Must be God's will. I was defending Bob's complication comment, but TPTB decided against it. My reply got whacked on "Post", and this is what remained:
Why complicate things ? You can use a simple
if (millis() - startTime >= period)
//code here to be executed at the end of the period
P.S. As usual, knowing the full use case & requirements saves everyone trying their best to help a lot of time, and in the process you get an answer you can use faster. Without this, well, this thread happens...
odometer:
Bad example because you likely would complain you waited 2hours and the food was cold and your server was rude and babies were crying the whole time..
UKHeliBob:
Is there a particular reason why you are using an interrupt when it is not strictly needed ?
Does the Serial.print() work in the ISR ? It depends on interrupts which are automatically disabled in ISRs
Why do repeatedly attach the interrupt in loop() and not just once in setup(), particularly as you never detach it ?
I believe that is the style of programming they teach at the University of Copy and Paste.
If you are referring to my post, then it comes from the University of I have asked two of these questions before and got no answer.
What I meant was: I believe that the reasom the the OP's (i.e. Techno500's) code looks the way it does is because he learned to program at the University of Copy and Paste.
As for using Serial.print() in an ISR: I've heard that you shouldn't, but why exactly shouldn't you? What are the consequences of using Serial.print() in an ISR? (I don't actually believe you should do it; I'm just playing devil's advocate here.)
