I have successfully built a simple stepper motor control circuit to operate a bipolar stepper motor using an Arduino UNO R3, and an Adafruit Motor Stepper Shield V2.3 The circuit is exactly as described by
Brian Schmalz with 3 momentary push buttons for Forward / Backward / Stop and a potentiometer for varying motor speed.
I have the circuit working as published but I would like to modify the sketch slightly to implement the "Release()" function to de-energize the stepper motor after the STOP pushbutton is depressed. Obviously, I am not a programmer and need some help in modifying the code. I would like for the forwardstep and backwardstep functions to still be available for subsequent moves after depressing the STOP pushbutton and releasing the motor.
Sorry about my programming ignorance, but I know that someone out there can point me in the right direction with this simple modification to the attached code.
Thanks in advance.
Rick Reeve
// Example6 code for Brian Schmalz's Easy Driver Example page
// http://www.schmalzhaus.com/EasyDriver/EasyDriverExamples.html
#include <AccelStepper.h>
#include <Wire.h>
#include <Adafruit_MotorShield.h>
// Define the stepper and the pins it will use
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
Adafruit_StepperMotor *motor1 = AFMS.getStepper(200, 2);
// you can change these to DOUBLE or INTERLEAVE or MICROSTEP!
void forwardstep() {
motor1->onestep(FORWARD, MICROSTEP);
void backwardstep() {
motor1->onestep(BACKWARD, MICROSTEP);
AccelStepper stepper1(forwardstep, backwardstep); // use functions to step
// Define our three input button pins
#define LEFT_PIN 2
#define STOP_PIN 3
#define RIGHT_PIN 4
// Define our analog pot input pin
#define SPEED_PIN A0
// Define our maximum and minimum speed in steps per second (scale pot to these)
#define MAX_SPEED 400
#define MIN_SPEED 0.1
AFMS.begin();
// The only AccelStepper value we have to set here is the max speeed, which is higher than we'll ever go
stepper1.setMaxSpeed(400.0);
// Set up the three button inputs, with pullups
pinMode(LEFT_PIN, INPUT_PULLUP);
pinMode(STOP_PIN, INPUT_PULLUP);
pinMode(RIGHT_PIN, INPUT_PULLUP);
static float current_speed = 0.0; // Holds current motor speed in steps/second
static int analog_read_counter = 1000; // Counts down to 0 to fire analog read
static char sign = 0; // Holds -1, 1 or 0 to turn the motor on/off and control direction
static int analog_value = 0; // Holds raw analog value.
// If a switch is pushed down (low), set the sign value appropriately
if (digitalRead(LEFT_PIN) == 0) {
sign = 1;
if (digitalRead(RIGHT_PIN) == 0) {
sign = -1;
if (digitalRead(STOP_PIN) == 0) {
sign = 0;
// We only want to read the pot every so often (because it takes a long time we don't
// want to do it every time through the main loop).
if (analog_read_counter > 0) {
analog_read_counter--;
else {
analog_read_counter = 3000;
// Now read the pot (from 0 to 1023)
analog_value = analogRead(SPEED_PIN);
// Give the stepper a chance to step if it needs to
stepper1.runSpeed();
// And scale the pot's value from min to max speeds
current_speed = sign * ((analog_value/1023.0) * (MAX_SPEED - MIN_SPEED)) + MIN_SPEED;
// Update the stepper to run at this new speed
stepper1.setSpeed(current_speed);
// This will run the stepper at a constant speed
