How to incorporate the SyRenSimplified::stop ( ) command to kill the Power
Hi Folks,
I'm trying to control DC Motor using the SyRen Motor Driver and, hence I included the "SyRenSimplified" Library.
I just wanted to kill the power after number of cycles and trying to use the SyRenSimplified::stop ( ) command as suggested by SyRenSimplified library.
I appreciate if anyone help me about how to incorporate this command in the Void Setup and in Void Loop.
Please consider the Pin 7 from Arduino Board is used as a stop pin.
Thank you.
Regards,
Gopi
That you got from WalMart?
Obviously not correctly. My crystal ball says that the problem is on line 677656787877654.
