How to increase 2 at 2 from 0 to 99
Hi, i am making a project about scoreboard for basketball, then I’m using three buttons and decoders and two display. I have achieved increasing an decreasing one point using the buttons but I have a problem with the button that increases two, when i have a number that ends at nine the display in the right must change to 1 and the left display must inscrease 1, on the other hand is the event when i have an eight on the right display if i push button to increase two the right display must change to 0 and the left increase in 1; the problem i have is that even i have an eight it increases but the right display does no change to zero but to 1; making the same process for when i have a nine , can someone please help how to increase 2 at 2 from 0 to 99… thanks
const int botonIncremento = 53;
const int botonIncremento2 = 50;
//const int botonIncremento3 = 51;
const int botonDecremento = 52;
const int deco_entradas1[4] = {26,27,28,29};//A, B, C, C entradas
const int deco_entradas2[4] = {38, 39, 40, 41};
int contador = 0;
int contador2 = 0;
int estadoBotonIncremento= 0;
int estadoBotonIncremento2 = 0;
int estadoAnteriorBotonIncremento = 0;
int estadoAnteriorBotonIncremento2 = 0;
int estadoBotonDecremento = 0;
int estadoAnteriorBotonDecremento = 0;
int tiempoBotonIncremento = 0;
pinMode(53, INPUT);
pinMode(50, INPUT);
pinMode(51, INPUT);
for(int a = 0; a < 4; a++){
pinMode(deco_entradas1[a], OUTPUT);}
for(int b = 0; b < 4; b++){
pinMode(deco_entradas2**, OUTPUT);}**
** estadoBotonIncremento = digitalRead(botonIncremento);**
** if(estadoBotonIncremento != estadoAnteriorBotonIncremento){**
** if(estadoBotonIncremento == HIGH)**
** delay(200);**
** contador++;**
** if (contador > 9)**
** contador = 0;**
** contador2++;**
** if (contador2 > 9)**
** contador = 0;**
** contador2=0;**
** estadoAnteriorBotonIncremento = estadoBotonIncremento;**
** estadoBotonIncremento2 = digitalRead(botonIncremento2);**
** if(estadoBotonIncremento2 != estadoAnteriorBotonIncremento2){**
** if(estadoBotonIncremento2 == HIGH)**
** delay(200);**
** contador = contador +2;**
** if (contador > 9 && (contador2 == 0 || contador2 > 0) )**
** contador2++;**
** contador = 1;**
** else if (contador > 8 && (contador2 == 0 || contador2 > 0))**
** contador2++;**
** contador = 0;**
** }estadoAnteriorBotonIncremento2 = estadoBotonIncremento2;**
** //Decremento**
** estadoBotonDecremento = digitalRead(botonDecremento);**
** if(estadoBotonDecremento != estadoAnteriorBotonDecremento){**
** if(estadoBotonDecremento == HIGH)**
** delay(200);**
// contador–;
// if (contador < 0)
// contador = 0;
** if (contador2 > 0 && contador == 0)
** contador = 9;**
** contador2–;**
** else if (contador2 == 0 && contador == 0)**
** contador2 = 0;**
** contador = 0;**
** else if (contador2 == 0 && contador > 0)**
** contador–;**
** else if (contador2 > 0 && contador > 0)**
** contador --;**
** estadoAnteriorBotonDecremento = estadoBotonDecremento;**
** switch(contador)**
** case 0:**
** digitalWrite(26, LOW);**
** digitalWrite(27, LOW);**
** digitalWrite(28, LOW);**
** digitalWrite(29, LOW);**
** break;**
** case 1:**
** digitalWrite(29, HIGH);**
** break;**
** case 2:**
** digitalWrite(28, HIGH);**
** break;**
** case 3:**
** break;**
** case 4:**
** digitalWrite(27, HIGH);**
** break;**
** case 5:**
** break;**
** case 6:**
** break;**
** case 7:**
** break;**
** case 8:**
** digitalWrite(26, HIGH);**
** break;**
** case 9:**
** break;**
** switch(contador2)**
** case 0:**
** digitalWrite(38, LOW);**
** digitalWrite(39, LOW);**
** digitalWrite(40, LOW);**
** digitalWrite(41, LOW);**
** break;**
** case 1:**
** digitalWrite(41, HIGH);**
** break;**
** case 2:**
** digitalWrite(40, HIGH);**
** break;**
** case 3:**
** break;**
** case 4:**
** digitalWrite(39, HIGH);**
** break;**
** case 5:**
** break;**
** case 6:**
** break;**
** case 7:**
** break;**
** case 8:**
** digitalWrite(38, HIGH);**
** break;**
** case 9:**
** break;**
        if(estadoBotonIncremento2 == HIGH) {
            delay(200);
            contador = contador + 2;
            if (contador >= 10) {
               contador2++;
               contador -= 10;
Please use code tags = #button above smileys...
