Hi guys
I want to increase my RF receivers voltage on the pins, i think at the moment when the pin goes high its around 2v, I need it to trigger a ultrasonic sensor which needs 5v.
Is there anyway to do this ?
Any help will be much appreciated.
Thanks
What RF receiver are you using, what pin are you referring to and are you trying to directly trigger the US from the receiver?
Hi I am going to be using these http://www.seeedstudio.com/wiki/index.php?title=315Mhz_RF_link_kits_-_with_encoder_and_decoder
I am referring to the output pins on the receiver, yes I am trying to trigger the US directly.
Use a transistor logic buffer. Its just 2 transistor inverters connected to each other. Simpler Inverter The output of one goes into the input of the other, and use that to trigger the US sensor
*Link fixed.
Thank you that makes sense .
According to the PT2272 decoder chip data sheet, the output pins are normal digital outputs. So if you are powering the receiver with 5 V, then the outputs will be either low (about 0 V) or high (about 5 V) depending on what data the transmitter is transmitting. If the output is 2 V, something is wrong.
The application example in the data sheet shows the PT2272 output powering an LED through a 560 ohm resistor, so it certainly should be able to trigger another digital circuit.
