Hi guys I need your help please. How can I increase the brightness of this effect:
* Arduino Uno - NeoPixel Fire
* v. 1.0
* Copyright (C) 2015 Robert Ulbricht
* https://www.arduinoslovakia.eu
* IDE: 1.8.5 or higher
* Board: Arduino or Arduino Pro Mini
* Libraries
* NeoPixel: https://github.com/adafruit/Adafruit_NeoPixel
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
// data pin
#define PIN 6
// led count
#define CNT 24
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_RGB Pixels are wired for RGB bitstream
// NEO_GRB Pixels are wired for GRB bitstream
// NEO_KHZ400 400 KHz bitstream (e.g. FLORA pixels)
// NEO_KHZ800 800 KHz bitstream (e.g. High Density LED strip)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(CNT, PIN, NEO_GRB + NEO_KHZ800);
uint32_t fire_color = strip.Color ( 80, 35, 00);
uint32_t off_color = strip.Color ( 0, 0, 0);
/// Fire simulator
class NeoFire
Adafruit_NeoPixel &strip;
public:
NeoFire(Adafruit_NeoPixel&);
void Draw();
void Clear();
void AddColor(uint8_t position, uint32_t color);
void SubstractColor(uint8_t position, uint32_t color);
uint32_t Blend(uint32_t color1, uint32_t color2);
uint32_t Substract(uint32_t color1, uint32_t color2);
/// Constructor
NeoFire::NeoFire(Adafruit_NeoPixel& n_strip)
: strip (n_strip)
/// Set all colors
void NeoFire::Draw()
Clear();
for(int i=0;i<CNT;i++)
AddColor(i, fire_color);
int r = random(80);
uint32_t diff_color = strip.Color ( r, r/2, r/2);
SubstractColor(i, diff_color);
strip.show();
/// Set color of LED
void NeoFire::AddColor(uint8_t position, uint32_t color)
uint32_t blended_color = Blend(strip.getPixelColor(position), color);
strip.setPixelColor(position, blended_color);
void NeoFire::SubstractColor(uint8_t position, uint32_t color)
uint32_t blended_color = Substract(strip.getPixelColor(position), color);
/// Color blending
uint32_t NeoFire::Blend(uint32_t color1, uint32_t color2)
uint8_t r1,g1,b1;
uint8_t r2,g2,b2;
uint8_t r3,g3,b3;
r1 = (uint8_t)(color1 >> 16),
g1 = (uint8_t)(color1 >> 8),
b1 = (uint8_t)(color1 >> 0);
r2 = (uint8_t)(color2 >> 16),
g2 = (uint8_t)(color2 >> 8),
b2 = (uint8_t)(color2 >> 0);
return strip.Color(constrain(r1+r2, 0, 255), constrain(g1+g2, 0, 255), constrain(b1+b2, 0, 255));
/// Color blending
uint32_t NeoFire::Substract(uint32_t color1, uint32_t color2)
uint8_t r1,g1,b1;
uint8_t r2,g2,b2;
uint8_t r3,g3,b3;
int16_t r,g,b;
r=(int16_t)r1-(int16_t)r2;
g=(int16_t)g1-(int16_t)g2;
b=(int16_t)b1-(int16_t)b2;
if(r<0) r=0;
if(g<0) g=0;
if(b<0) b=0;
return strip.Color(r, g, b);
/// Every LED to black
void NeoFire::Clear()
for(uint16_t i=0; i<strip.numPixels (); i++)
strip.setPixelColor(i, off_color);
NeoFire fire(strip);
/// Setup
strip.begin();
strip.show(); // Initialize all pixels to 'off'
/// Main loop
fire.Draw();
delay(random(50,150));
Looking forward for your help.
