Hello,
I'm trying to solve the following problem: increase PWM to control DC motor, at specific time interval, every 200 ms, while counting the total encoder ticks during that interval and increase the PWM in steps from 0 to 255 and decrease in steps back to 0.
Here is my attempt using Timer2 library. The timer ISR works and the PWM value increases from 0 to 255 at a defined time interval. But i can't figure out how to make the PWM go back to 0 at the same time interval and also display the total encoder ticks during each interval.
#include <MsTimer2.h>
const int motor_AIN1 = 8; //set the motor driver pins
const int motor_AIN2 = 12;
const int motor_PWMA = 10;
const int motor_EncoderA = 2; //set the encoder pin.
volatile long encoder_count = 0;
int PWMvalue = 0; //initialise PWM value
int copy_encoder_count = 0; //copy encoder count
#define INTERVAL 200 //time interval in milliseconds to run timer interrupt function
volatile bool state = false;
void setup() //execute only once
//set the control pins of motor to OUTPUT
pinMode(motor_AIN1,OUTPUT);
pinMode(motor_AIN2,OUTPUT);
pinMode(motor_PWMA,OUTPUT);
//speed encoder input
pinMode(motor_EncoderA, INPUT_PULLUP);
//wait 1 second before starting the motor
delay (1000);
attachInterrupt(digitalPinToInterrupt(motor_EncoderA), encoderISR, CHANGE); //RISING or FALLING or LOW or CHANGE
MsTimer2::set(INTERVAL, timerFunction); //configures the interrupt function to run every time interval in ms.
MsTimer2::start(); //start interrupt
if (state == true)
printValues();
if(PWMvalue < 255) //the PWM value should never exceed 255.
PWMvalue++;
digitalWrite(motor_AIN1, HIGH);
digitalWrite(motor_AIN2, LOW);
analogWrite(motor_PWMA, PWMvalue);
state = !state;
void encoderISR() //increments the value of the encoder count every pulse
encoder_count++;
void printValues()
Serial.print("Time interval: "); //PWM value and the corresponding total encoder pulses every time interval in ms.
Serial.print(INTERVAL);
Serial.print(" ms. ");
Serial.print("PWM value: ");
Serial.print(PWMvalue);
Serial.print(". ");
Serial.print("Total encoder pulses: ");
Serial.println(copy_encoder_count);
void timerFunction() //timer interrupt function
//interrupts are disabled by default when the timer ISR is running
copy_encoder_count = encoder_count; //assign the value counted by encoder to copy_encoder_count
encoder_count = 0; //Reset the count value
state = !state; //toggle state
Here is an initial part of the output on the Arduino IDE Serial Monitor:
Time interval: 200 ms. PWM value: 0. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 1. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 2. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 3. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 4. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 5. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 6. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 7. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 8. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 9. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 10. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 11. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 12. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 13. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 14. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 15. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 16. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 17. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 18. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 19. Total encoder pulses: 1
Time interval: 200 ms. PWM value: 20. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 21. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 22. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 23. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 24. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 25. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 26. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 27. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 28. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 29. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 30. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 31. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 32. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 33. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 34. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 35. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 36. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 37. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 38. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 39. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 40. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 41. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 42. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 43. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 44. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 45. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 46. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 47. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 48. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 49. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 50. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 51. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 52. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 53. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 54. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 55. Total encoder pulses: 0
Time interval: 200 ms. PWM value: 56. Total encoder pulses: 9
Time interval: 200 ms. PWM value: 57. Total encoder pulses: 33
Time interval: 200 ms. PWM value: 58. Total encoder pulses: 40
Time interval: 200 ms. PWM value: 59. Total encoder pulses: 42
Time interval: 200 ms. PWM value: 60. Total encoder pulses: 43
Time interval: 200 ms. PWM value: 61. Total encoder pulses: 44
Time interval: 200 ms. PWM value: 62. Total encoder pulses: 45
Time interval: 200 ms. PWM value: 63. Total encoder pulses: 47
Time interval: 200 ms. PWM value: 64. Total encoder pulses: 47
Time interval: 200 ms. PWM value: 65. Total encoder pulses: 48
Time interval: 200 ms. PWM value: 66. Total encoder pulses: 50
Time interval: 200 ms. PWM value: 67. Total encoder pulses: 50
Time interval: 200 ms. PWM value: 68. Total encoder pulses: 51
Time interval: 200 ms. PWM value: 69. Total encoder pulses: 53
The PWM goes up to 255 and then it stays there indefinitely.
