How to increase the measurement speed of the pulse sensor
Hello everyone, I am working on a school project which uses Arduino UNO and pulse sensor SEN-11574 from pulsesensor.com to measure the heart rate. I want to ask if anyone knows how to increase the measurement speed of the pulse sensor. Now it will take about 10 seconds to measure the heart rate. I think it is too slow. I want to reduce it to less than 5 seconds. Does anybody have any pieces of advice? Should I modify the code or hardware? Thank you very much in advance. Following is the code that I am using right now.
#define USE_ARDUINO_INTERRUPTS true    // Set-up low-level interrupts for most acurate BPM math.
#include <PulseSensorPlayground.h>     // Includes the PulseSensorPlayground Library.
//  Variables
const int PulseWire = 0;       // PulseSensor PURPLE WIRE connected to ANALOG PIN 0
int Threshold = 550;           // Determine which Signal to "count as a beat" and which to ignore.
                               // Use the "Gettting Started Project" to fine-tune Threshold Value beyond default setting.
                               // Otherwise leave the default "550" value.
PulseSensorPlayground pulseSensor;  // Creates an instance of the PulseSensorPlayground object called "pulseSensor"
  Serial.begin(9600);          // For Serial Monitor
 // initialize digital pin2  as an output.
  pinMode(2, OUTPUT);
  // Configure the PulseSensor object, by assigning our variables to it.
  pulseSensor.analogInput(PulseWire);
  pulseSensor.setThreshold(Threshold);
  // Double-check the "pulseSensor" object was created and "began" seeing a signal.
   if (pulseSensor.begin()) {
    Serial.println("We created a pulseSensor Object !");  //This prints one time at Arduino power-up,  or on Arduino reset.
 int myBPM = pulseSensor.getBeatsPerMinute();  // Calls function on our pulseSensor object that returns BPM as an "int".
                                               // "myBPM" hold this BPM value now.
if (pulseSensor.sawStartOfBeat()) {            // Constantly test to see if "a beat happened".
 Serial.println("♥  A HeartBeat Happened ! "); // If test is "true", print a message "a heartbeat happened".
 Serial.print("BPM: ");                        // Print phrase "BPM: "
 Serial.println(myBPM);                        // Print the value inside of myBPM.
 if(myBPM >= 80){                          // If the signal is above "550", then "turn-on" Arduino's on-Board LED.
      digitalWrite(2, LOW);
      delay(50);
      digitalWrite(2, HIGH);
      delay(50);
   } else if (myBPM >= 70 && myBPM < 80){
      delay(100);
      delay(100);
   else if (myBPM >= 60 && myBPM < 70){
   else {
       digitalWrite(2, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);                       // wait for a second
  digitalWrite(2, LOW);    // turn the LED off by making the voltage LOW
else {
  digitalWrite(2,LOW);                //  Else, the sigal must be below "550", so "turn-off" this LED.
  delay(20);                    // considered best practice in a simple sketch.
@DragonPig, do not cross-post. Other thread removed.
so sorry about that! I didn't know
To make it give a number faster (but less accurate as you had less beats) you will have to make changes to the PulseSensorPlayground library.
Wow! Thank you so much!! But can I modify the PulseSensorPlayground library?
Of course.
Thank you, I had taken a look at the code but I am not sure which line of code should I modify and I couldn't find any guide online. Should modify this line? THANK YOU VERY MUCH if you can help me! :sob: :sob:
static const unsigned long MICROS_PER_READ = (2 * 1000L); // usecs per sample
This is the code for pulsesensorplayground library
#ifndef PULSE_SENSOR_PLAYGROUND_H
#define PULSE_SENSOR_PLAYGROUND_H
#define PULSE_SENSOR_TIMING_ANALYSIS false
#define PULSE_SENSOR_MEMORY_USAGE false
//#define PULSE_SENSOR_MEMORY_USAGE true
#include <Arduino.h>
#include "utility/PulseSensor.h"
#include "utility/PulseSensorSerialOutput.h"
#include "utility/PulseSensorTimingStatistics.h"
class PulseSensorPlayground {
  public:
       The number of microseconds per sample of data from the PulseSensor.
       1 millisecond is 1,000 microseconds.
       Refer to this value as PulseSensorPlayground::MICROS_PER_READ
    static const unsigned long MICROS_PER_READ = (2 * 1000L); // usecs per sample.
    //---------- PulseSensor Manager functions
    PulseSensorPlayground(int numberOfSensors = 1);
       Start reading and processing data from the PulseSensors.
       Your Sketch should make all necessary PulseSensor configuration calls
       before calling begin().
       If the Sketch defined USE_ARDUINO_INTERRUPTS as true, this function
       sets up and turns on interrupts for the PulseSensor.
       If instead the Sketch defined USE_ARDUINO_INTERRUPTS as false,
       it initializes what's necessary for the Sketch to process
       PulsSensor signals. See sawNewSample(), below.
       Returns true if successful, false if unsuccessful.
       Returns false if PulseSensorPlayground doesn't yet support
       interrupts on this Arduino platform and the user's Sketch
       did a #define USE_ARDUINO_INTERRUPTS true.
       If begin() returns false, you can either use a different
       type of Arduino platform, or you can change your Sketch's
       definition of USE_ARDUINO_INTERRUPTS to false:
         #define USE_ARDUINO_INTERRUPTS false
    boolean begin();
       Returns true if a new sample has been read from each PulseSensor.
       You'll likely want to add this call to your Sketch's loop()
       only if you either 1) want to do something with each sample of the
       PulseSensor signals, or 2) your Sketch doesn't use interrupts
       to read from the PulseSensors.
       NOTE: If your Sketch defined USE_ARDUINO_INTERRUPTS as false,
       you must call pulse.sawNewSample() frequently (at least
       once every 2 milliseconds) to assure that PulseSensor signals
       are read accurately.
       A typical loop() that doesn't use interrupts will contain:
         if (pulse.sawNewSample()) {
           int latest = pulse.getLatestSample();
           ...do whatever you want with the sample read from the PulseSensor.
    boolean sawNewSample();
    //---------- Per-PulseSensor functions
    void analogInput(int inputPin, int sensorIndex = 0);
    void blinkOnPulse(int blinkPin, int sensorIndex = 0);
    void fadeOnPulse(int fadePin, int sensorIndex = 0);
    void onSampleTime();
       Returns the most recently read analog value from the given PulseSensor
       (range: 0..1023).
       sensorIndex = optional, index (0..numberOfSensors - 1)
         of the PulseSensor of interest.
    int getLatestSample(int sensorIndex = 0);
       Returns the latest beats-per-minute measure for the given PulseSensor.
       The internal beats-per-minute measure is updated per-PulseSensor,
       when a beat is detected from that PulseSensor.
    int getBeatsPerMinute(int sensorIndex = 0);
       Returns the latest IBI (inter-beat interval, in milliseconds) measure
       The internal IBI measure is updated per-PulseSensor,
    int getInterBeatIntervalMs(int sensorIndex = 0);
       Returns true if a new heartbeat (pulse) has been detected
       from the given PulseSensor since the last call to sawStartOfBeat()
       on this PulseSensor.
       Typical use in loop():
         if (pulse.sawStartOfBeat()) {
           ...do what you want to do per-heartbeat.
    boolean sawStartOfBeat(int sensorIndex = 0);
       Returns true if the given PulseSensor signal is currently
       inside a heartbeat. That is, returns true if the signal is above
       the automatically-set threshold of a beat, false otherwise.
         if (pulse.isInsideBeat()) {
           ...do what you want while in the beat.
           ...do what you want while between beats.
    boolean isInsideBeat(int sensorIndex = 0);
    //---------- Serial Output functions
    void setSerial(Stream &output);
    void setOutputType(byte outputType);
    void setThreshold(int threshold, int sensorIndex = 0);
    void outputSample();
    void outputToSerial(char symbol, int data);
    int getPulseAmplitude(int sensorIndex = 0);
       Returns the sample number when the last beat was found. 2mS resolution.
    unsigned long getLastBeatTime(int sensorIndex = 0);
       Output the current per-beat information for each PulseSensor,
       in the previously-set outputType.
       If your Sketch wants to plot beat information, it should call this
       function every time a beat is detected.
       Typical use:
           pulse.outputBeat();
    void outputBeat(int sensorIndex = 0);
    // (internal to the library) "this" pointer for the ISR.
    static PulseSensorPlayground *OurThis;
  private:
    void setupInterrupt();
#if PULSE_SENSOR_MEMORY_USAGE
    void printMemoryUsage();
#endif // PULSE_SENSOR_MEMORY_USAGE
    static boolean UsingInterrupts;
    byte SensorCount;              // number of PulseSensors in Sensors[].
    PulseSensor *Sensors;          // use Sensors[idx] to access a sensor.
    volatile unsigned long NextSampleMicros; // Desired time to sample next.
    volatile boolean SawNewSample; // "A sample has arrived from the ISR"
    PulseSensorSerialOutput SerialOutput; // Serial Output manager.
#if PULSE_SENSOR_TIMING_ANALYSIS   // Don't use ram and flash we don't need.
    PulseSensorTimingStatistics *pTiming;
#endif // PULSE_SENSOR_TIMING_ANALYSIS
#include "utility/Interrupts.h"
#endif // PULSE_SENSOR_PLAYGROUND_H
You'll just have to analyse the code and find out how it works, and how it sets the sample rate. A line that mentions a timing of 2000 us doesn't sound like the part where it takes 10 seconds between readings.
