How to initialize the value of a union struct?
I have this struct to easily access the bits of a byte
typedef union
  uint8_t vbyte;
  struct
    uint8_t b0:1;
    uint8_t b1:1;
    uint8_t b2:1;
    uint8_t b3:1;
    uint8_t b4:1;
    uint8_t b5:1;
    uint8_t b6:1;
    uint8_t b7:1;
 } byte_bits;
I need to declare and initialize the value of the variable to 0xFF.
The compile is OK with
static byte_bits long_press_ack;
But the compiler does not like
static byte_bits long_press_ack.vbyte = 0xFF;
I can't believe google can't find a declaration for this. This must be possible.
Whereabouts in the program are you doing this ?
In a subroutine, hence the static.
void scan_buttons()
Even as a global (without the static), it doesn't like
The struct in the union has no name, and you probably need to:
static byte_bits long_press_ack = { 0xFF };
This seems to work:
typedef union
  uint8_t vbyte;
  struct
    uint8_t b0:1;
    uint8_t b1:1;
    uint8_t b2:1;
    uint8_t b3:1;
    uint8_t b4:1;
    uint8_t b5:1;
    uint8_t b6:1;
    uint8_t b7:1;
   }Bits;
 } byte_bits;
    while(!Serial);
}//setup
    foo();
}//loop
void foo( void )
    static byte_bits
        long_press_ack =
            .vbyte = 0xa5
    Serial.println( long_press_ack.vbyte,HEX );
    Serial.print( long_press_ack.Bits.b7 );
    Serial.print( long_press_ack.Bits.b6 );
    Serial.print( long_press_ack.Bits.b5 );
    Serial.print( long_press_ack.Bits.b4 );
    Serial.print( long_press_ack.Bits.b3 );
    Serial.print( long_press_ack.Bits.b2 );
    Serial.print( long_press_ack.Bits.b1 );
    Serial.println( long_press_ack.Bits.b0 );
}//foo
