How to insert arduino variable value in HTML table while developing web page
I'm working on Arduino WiFi MKR 1010, I want to get a value from a table on my webpage to toogle a led (pin 6).
Can someone help me please ?
this is my code:
#include <SPI.h>
#include <WiFiNINA.h>
#include <Servo.h>
char ssid[] = "******";
char pass[] = "******";
int keyIndex = 0;
int status = WL_IDLE_STATUS;
WiFiServer server(80);
//special characters
char quote = '"';
char slash = '/';
Servo myservo;
 Serial.begin(9600);      // initialize serial communication
 pinMode(6, OUTPUT);      // set the LED pin mode
 pinMode(7, OUTPUT);
 myservo.attach(9);
 myservo.write(45);
 // check for the presence of the shield:
 if (WiFi.status() == WL_NO_SHIELD) {
   Serial.println("WiFi shield not present");
   while (true);       // don't continue
 // attempt to connect to WiFi network:
 while ( status != WL_CONNECTED) {
   Serial.print("Attempting to connect to Network named: ");
   Serial.println(ssid);                   // print the network name (SSID);
   // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
   status = WiFi.begin(ssid, pass);
   // wait 10 seconds for connection:
   delay(10000);
 server.begin();                           // start the web server on port 80
 printWiFiStatus();                        // you're connected now, so print out the status
   delay(10000);
 WiFiClient client = server.available();   // listen for incoming clients
 if (client) {
   Serial.println("new client");
   String currentLine = "";
   while (client.connected()) {
     if (client.available()) {
       char c = client.read();
       Serial.write(c);
       if (c == '\n') {
         if (currentLine.length() == 0) {
           client.println("Content-type:text/html");
           client.println("Content-Type: application/x-javascript");
           client.println();
           client.println("<!DOCTYPE HTML>");
           client.print("<head>");
           client.print("</head>");
           client.print("<body>");
           client.println("<center>
<div class='container'><h1>CONTROL YOUR ARDUINO<h1/></div></center>");
           client.print("<center><h2> LED Rouge");
           client.println("</h2>");
           client.println("<center><div class='container'><left><button class='on' type='submit' value='ON' onmousedown=location.href='/H\'>ON</button>");
           client.println("<button class='off' type='submit' value='OFF' onmousedown=location.href='/L\'>OFF</button></div>
           client.print("<h2> LED Verte");
           client.println("<center><div class='container'><left><button class='on' type='submit' value='ON' onmousedown=location.href='/X\'>ON</button>");
           client.println("<button class='off' type='submit' value='OFF' onmousedown=location.href='/P\'>OFF</button></div>
           client.print("<from action='/get>'>");
           client.print("<input type='number' name=r id = 'input'> Clignotant LED
           client.println("<button class='submit' type='submit' value='set' onmousedown=location.href='/T\' onclick='getInputValue();'>Get Value</button></div>
           client.print("<script>");
           client.print("funtion getInputValue()");
           client.println("{");
           client.println("var inputVal = document.getElementById('input').value");
           client.println("alert(inputVal)");
           client.println("}</script>");
client.print("<script>function save(tableID)");
client.print("{");
client.print("var a = document.getElementById(tableID).value;");
client.print("var x = alert(col[0].firstChild.innerHTML);");
client.print("} </script>");
client.print("<h2>Choisir_LED</h2>");
client.print("<input type='button' name='btnSave' value='Save' onclick='save('dataTable')' />");
client.print("<input type='button' value='Add Row' onclick='addRow('dataTable')' />");
client.print("<input type='button' value='Delete Row' onclick='deleteRow('dataTable')' />");
client.print("<table id='table1' width='400px' border='0' >");
    client.print("<tr>");
    client.print("<td style='padding-left:30px'>Nom de la LED</td>");
    client.print("<td style='padding-left:120px'>Nb clignant</td>");
    client.print("</tr>");
    client.print("<table id='dataTable' width='350px' border='1'>");
    client.print("<td><input type='checkbox' name='chk'/></td>");
    client.print("<td><input type='text' name='txt1' /></td>");
    client.print("<td><input type='text' name='txt'/></td>");
client.print(" </tr> </table> </table>");
           client.println("</body>");
           client.println("</html>");
           client.println();
         else {
           currentLine = "";
       else if (c != '\r') {    // if you got anything else but a carriage return character,
         currentLine += c;      // add it to the end of the currentLine
       if (currentLine.endsWith("GET /X")) {
        for(int i= 0 ; i< parsInt(a) ; i++){
         digitalWrite(6, HIGH);                // GET /L turns the pin 6 LED off
         digitalWrite(6, LOW);
   // close the connection:
   client.stop();
   Serial.println("client disonnected");
void printWiFiStatus() {
 // print the SSID of the network you're attached to:
 Serial.print("SSID: ");
 Serial.println(WiFi.SSID());
 // print your WiFi shield's IP address:
 IPAddress ip = WiFi.localIP();
 Serial.print("IP Address: ");
 Serial.println(ip);
 // print the received signal strength:
 long rssi = WiFi.RSSI();
 Serial.print("signal strength (RSSI):");
 Serial.print(rssi);
 Serial.println(" dBm");
 // print where to go in a browser:
 Serial.print("To see this page in action, open a browser to http://");
 Serial.println(ip);
To put your code in a code box, use the </> icon in the far left of the post tool bar and paste your code between the two bracket sets that appear.
To go back and put your code in a code box, in the bottom right of your post, select "more" and click modify. When the modify post opens, high light your code and click the </> in the far left of the post tool bar. This will put you code in code brackets. Then save the changes.
You should read the "Read this before posting a program question..." at the top of the discussion list.
