Good afternoon!
Risently I bought the Leonardo. Before that, I used Nano with the CP340 driver. Everything worked.
IDE with the Leonardo does not see my COM7. How to install it? Do I need some driver ? Someone advised to switch the Reset and GND while uploading. It didn't help at all. Any ideas?
What does Windows device manager say when you connect your board? Further, if COM7 was your Nano, it will more than likely not be your Leonardo.
A common reason why a board with microUSB connector is not recognised is the use of a charge-only cable (those that come with e.g. a power bank). Try a different cable that is known to be a good sync cable; if you have a cell-phone with microUSB, use the cable that came with it that allows you to e.g. download photos fromthe phonew to the PC.
Windows does not respond at all. The Device Manager does not see any new device on COM7.
Of course I use the same cable and the same COM7 port as for the Nano.
Only I'm not connecting the power connector to the Leonardo yet. Micro-USB cable only.
A Leonardo has a microUSB, a standard Nano (and most nano clones) have miniUSB. So "of course" is not applicable
As said, it more than likely is not COM7.
What happens when you press and release the reset button on the Leonardo (you might have to double tap instead of press/release)? Does the L LED fade in and out for approx. 8 seconds? If yes, what does Windows device manager say while the L LED is fading?
Have a look where the drivers arte located on your Win10 PC and copy them to somewhere on your Win7 PC; location is not really relevant. Next you should be able to install them.
If you have official Arduino Leonardo, then use the new IDE 2.0 and a good data USB cable, the IDE will auto detect it when you connect it to your computer.
