Hi everyone! I am new here and I find this site really fascinating. By the way, I am trying to figure out how to connect the output of my sound activated switch (Please see attached schematic below) to the digital input pin of my arduino.
Am I correct that this circuit acts like a push button switch except that this is sound activated. Also, attached is a simple code I made for this experiment.
int Button = 8; //Output of the Sound Activated Switch
int Led = 13;
pinMode(Button, INPUT);
pinMode(Led, OUTPUT);
if (digitalRead(Button) == HIGH)
digitalWrite(Led, HIGH);
digitalWrite(Led, LOW);
As long as output is no more than 5V, you can connect it directly to arduino. Just connect sensor's ground ( GND ) to arduino's gnd , OUTPUT to any of the digital or analog pins . You can power the sensor from Arduino's 5V output.
Lows, -0.5V to 1.5V
Highs 3V to 5.5V.
Too low, too high will damage the IO pins.
1.5V to 3V will produce indeterminate digital readings.
Don't forget GND to Gnd as indicated.
CrossRoads:
Lows, -0.5V to 1.5V
Highs 3V to 5.5V.
Thank you sir! I think I am having indeterminate digital readings.. still having trouble with this circuit.
