how to interface arduino mega with ls-y201
iam new to working with arduino. Can anyone guide me plz? or if there is any error free code? thanks in advance!
what is an ls-y201? never heard of it? do you have a datasheet? can you post your code what you have tried sofar? can you describe what worked and what not?
ls-y201 is a camera which iam using for my project.
my project is to create a “geographical view creator”. I have to take a pic from camera then store that pic on sd card using arduino mega 2560.
i tried many codes but no useful.
i have downloaded arduino 1.5.6 … is it suitable?
and here is my code … plz can u explain me in detail how to work on it? :frowning:
i shall be very thankful to u :’)
#include <SoftwareSerial.h>
byte incomingbyte;
//Configure pin 2 and 3 as soft serial port
SoftwareSerial cameraSerial = SoftwareSerial(2, 3);
int a=0x0000,  //Read Starting address
    j=0,
    k=0,
    count=0;
uint8_t MH,ML;
boolean EndFlag=0;
  Serial.begin(19200);
  cameraSerial.begin(38400);
  SendResetCmd();
  delay(3000);
  SendTakePhotoCmd();
  Serial.println("Start pic");
  delay(100);
  while(cameraSerial.available()>0) {
    incomingbyte=cameraSerial.read();
  byte b[32];
  while(!EndFlag) {
    j=0;
    k=0;
    count=0;
    SendReadDataCmd();
    delay(75); //try going up
      k++;
      if((k>5)&&(j<32)&&(!EndFlag)) {
        b[j]=incomingbyte;
        if((b[j-1]==0xFF)&&(b[j]==0xD9))
        EndFlag=1;
        j++;
        count++;
    for(j=0;j<count;j++) {
      if(b[j]<0x10)
        Serial.print("0");
      Serial.print(b[j], HEX);
  delay(3000);
  EndFlag = 0; // reset so that another picture can be taken
  Serial.println("End of pic");
//Send Reset command
void SendResetCmd() {
  cameraSerial.write((byte)0x56);
  cameraSerial.write((byte)0x00);
  cameraSerial.write((byte)0x26);
//Send take picture command
void SendTakePhotoCmd() {
  cameraSerial.write((byte)0x36);
  cameraSerial.write((byte)0x01);
  a = 0x0000; //reset so that another picture can taken
void FrameSize() {
  cameraSerial.write((byte)0x34);
//Read data
void SendReadDataCmd() {
  MH=a/0x100;
  ML=a%0x100;
  cameraSerial.write((byte)0x32);
  cameraSerial.write((byte)0x0c);
  cameraSerial.write((byte)0x0a);
  cameraSerial.write((byte)MH);
  cameraSerial.write((byte)ML);
  cameraSerial.write((byte)0x20);
  a+=0x20;
void StopTakePhotoCmd() {
  cameraSerial.write((byte)0x03);
