// TFT display and SD card will share the hardware SPI interface.
// Hardware SPI pins are specific to the Arduino board type and
// cannot be remapped to alternate pins. For Arduino Uno,
// Duemilanove, etc., pin 11 = MOSI, pin 12 = MISO, pin 13 = SCK.
#define TFT_CS 10 // Chip select line for TFT display
#define TFT_RST 9 // Reset line for TFT (or see below...)
//Use this reset pin for the shield!
//#define TFT_RST -1 // you can also connect this to the Arduino reset!
#define TFT_DC 8 // Data/command line for TFT
#define SD_CS 4 // Chip select line for SD card
// For 0.96", 1.44" and 1.8" TFT with ST7735 use
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
// For 1.54" TFT with ST7789
//Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_RST);
void setup(void) {
while (!Serial) {
delay(10); // wait for serial console
pinMode(TFT_CS, OUTPUT);
digitalWrite(TFT_CS, HIGH);
pinMode(SD_CS, OUTPUT);
digitalWrite(SD_CS, HIGH);
// Use this initializer if you're using a 1.8" TFT
tft.initR(INITR_BLACKTAB);
// Use this initializer (uncomment) if you're using a 1.44" TFT
//tft.initR(INITR_144GREENTAB);
// Use this initializer (uncomment) if you're using a 0.96" 180x60 TFT
//tft.initR(INITR_MINI160x80); // initialize a ST7735S chip, mini display
// Use this initializer (uncomment) if you're using a 1.54" 240x240 TFT
//tft.init(240, 240); // initialize a ST7789 chip, 240x240 pixels
