How to Interface the CH Robotics UM6 with the Arduino
Hi, I have a CH Robotics UM6 and am trying to figure out how to get it to work with an arduino uno through serial comm.
I have been looking through JonRussells code which he posted :
#include <NewSoftSerial.h>
NewSoftSerial UM6Serial(2,3);
int nState = 0;
#define STATE_ZERO         0
#define STATE_S            1
#define STATE_SN           2
#define STATE_SNP          3
#define STATE_PT           4
#define STATE_READ_DATA    5
#define STATE_CHK1         6
#define STATE_CHK0         7
#define STATE_DONE         8
#define UM6_GET_DATA       0xAE
#define UM6_QUAT_AB        0x64
#define UM6_QUAT_CD        0x65
#define UM6_GYRO_PROC_XY   0x5C
#define UM6_GYRO_PROC_Z    0x5D
#define UM6_ACCEL_PROC_XY  0x5E
#define UM6_ACCEL_PROC_Z   0x5F
#define QUAT_SCALE_FACTOR  0.0000335693   // Convert to Quaternions
#define ACCEL_SCALE_FACTOR 0.000183105    // Convert to Gravity
#define GYRO_SCALE_FACTOR  0.0610352      // Convert to Degrees per Second
#define PT_HAS_DATA  0b10000000
#define PT_IS_BATCH  0b01000000
#define PT_COMM_FAIL 0b00000001
#define DATA_BUFF_LEN  16
byte aPacketData[DATA_BUFF_LEN];
int n = 0;
byte c = 0;
int nDataByteCount = 0;
typedef struct {
  boolean HasData;
  boolean IsBatch;
  byte BatchLength;
  boolean CommFail;
  byte Address;
  byte Checksum1;
  byte Checksum0;
  byte DataLength;
} UM6_PacketStruct ;
UM6_PacketStruct UM6_Packet;
void setup(){
  UM6Serial.begin(19200);
void loop(){
  n = UM6Serial.available();
  if (n > 0){
    c = UM6Serial.read();
    Serial.println(c, BYTE);
    switch(nState){
      case STATE_ZERO : // Begin. Look for 's'.
        // Start of new packet...
        Reset();
        if (c == 's'){
          nState = STATE_S;
          nState = STATE_ZERO;
      case STATE_S : // Have 's'. Look for 'n'.
        if (c == 'n'){
          nState = STATE_SN;
      case STATE_SN : // Have 'sn'. Look for 'p'.
        if (c == 'p'){
          nState = STATE_SNP;
      case STATE_SNP : // Have 'snp'. Read PacketType and calculate DataLength.
        UM6_Packet.HasData = 1 && (c & PT_HAS_DATA);
        UM6_Packet.IsBatch = 1 && (c & PT_IS_BATCH);
        UM6_Packet.BatchLength = ((c >> 2) & 0b00001111);
        UM6_Packet.CommFail = 1 && (c & PT_COMM_FAIL);
        nState = STATE_PT;
        if (UM6_Packet.IsBatch){
          UM6_Packet.DataLength = UM6_Packet.BatchLength * 4;
          UM6_Packet.DataLength = 4;
      case STATE_PT : // Have PacketType. Read Address.
        UM6_Packet.Address = c;
        nDataByteCount = 0;
        nState = STATE_READ_DATA;
      case STATE_READ_DATA : // Read Data. (UM6_PT.BatchLength * 4) bytes.
        aPacketData[nDataByteCount] = c;
        nDataByteCount++;
        if (nDataByteCount >= UM6_Packet.DataLength){
          nState = STATE_CHK1;
      case STATE_CHK1 : // Read Checksum 1
        UM6_Packet.Checksum1 = c;
        nState = STATE_CHK0;
      case STATE_CHK0 : // Read Checksum 0
        UM6_Packet.Checksum0 = c;
        nState = STATE_DONE;
      case STATE_DONE : // Entire packet consumed. Process packet
        ProcessPacket();
void ProcessPacket(){
float DataA = 0;
float DataB = 0;
float DataC = 0;
float DataD = 0;
int i = 0;
  PrintDebugPacketData();
  switch(UM6_Packet.Address){
    case UM6_QUAT_AB :
      Serial.print("UM6_QUAT_AB : ");
      if (UM6_Packet.HasData && !UM6_Packet.CommFail){
        i = (aPacketData[0] << 8) | aPacketData[1];
        DataA = i * QUAT_SCALE_FACTOR;
        i = (aPacketData[2] << 8) | aPacketData[3];
        DataB = i * QUAT_SCALE_FACTOR;
        if (UM6_Packet.DataLength > 4){
          i = (aPacketData[4] << 8) | aPacketData[5];
          DataC = i * QUAT_SCALE_FACTOR;
          i = (aPacketData[6] << 8) | aPacketData[7];
          DataD = i * QUAT_SCALE_FACTOR;
      PrintDebugFloatABCD(DataA,DataB,DataC,DataD);
    case UM6_ACCEL_PROC_XY :
      Serial.print("UM6_ACCEL_PROC_XY : ");
        DataA = i * ACCEL_SCALE_FACTOR;
        DataB = i * ACCEL_SCALE_FACTOR;
          DataC = i * ACCEL_SCALE_FACTOR;
    case UM6_GYRO_PROC_XY :
      Serial.print("UM6_GYRO_PROC_XY : ");
        DataA = i * GYRO_SCALE_FACTOR;
        DataB = i * GYRO_SCALE_FACTOR;
          DataC = i * GYRO_SCALE_FACTOR;
    // case else
    Serial.println("*** Unknown Packet ***");
void Reset(){
  UM6_Packet.HasData = false;
  UM6_Packet.IsBatch = false;
  UM6_Packet.BatchLength = 0;
  UM6_Packet.CommFail = false;
  UM6_Packet.Address = 0;
  UM6_Packet.Checksum1 = 0;
  UM6_Packet.Checksum0 = 0;
  UM6_Packet.DataLength = 0;
void PrintDebugPacketData(){
  Serial.print("N = ");
  Serial.print(n,DEC);
  Serial.print(" HD = ");
  Serial.print(UM6_Packet.HasData,BIN);
  Serial.print(" IB = ");
  Serial.print(UM6_Packet.IsBatch,BIN);
  Serial.print(" BL = ");
  Serial.print(UM6_Packet.BatchLength,DEC);
  Serial.print(" CF = ");
  Serial.print(UM6_Packet.CommFail,BIN);
  Serial.print(" AD = 0x");
  Serial.print(UM6_Packet.Address,HEX);
  Serial.print(" CS1 = 0x");
  Serial.print(UM6_Packet.Checksum1,HEX);
  Serial.print(" CS0 = 0x");
  Serial.print(UM6_Packet.Checksum0,HEX);
  Serial.print(" DL = ");
  Serial.print(UM6_Packet.DataLength,DEC);
  Serial.println(".");
void PrintDebugFloatABCD(float a, float b, float c, float d){
  Serial.print(" A = ");
  Serial.print(a,DEC);
  Serial.print(" B = ");
  Serial.print(b,DEC);
  Serial.print(" C = ");
  Serial.print(c,DEC);
  Serial.print(" D = ");
  Serial.print(d,DEC);
The code runs fine and the um6 powers up so it seems like the wires are connected correctly, but none of the print statements ever get called and when I put in my own print lines to check the serial.read of the board, I get garbage (i.e. lots of ASCII symbols, no actual english letters).
Is there any type of setup that I need to do to the UM6 to get it to work? Its obviously communicating with the arduino which is in turn sending us stuff to the serial monitor, but its not sending the right stuff.
If anybody knows how to solve this problem, I would greatly appreciate any help that you can give.
Thank you,
Kyle
A link to the device in question would not be inappropriate.
Baude rate and rs232/TTL might be issues.
My apologies, this is the devices data sheet http://www.chrobotics.com/docs/UM6_datasheet.pdf
and here is the product: http://69.164.223.22/catalog/product/1256
Could you please explain what you mean when you say baud rate and rs232/ttl might be the problem?
Thanks ,
Kyle
To check your baud rate, look at the bottom right of the serial monitor. It needs to be set to 19200.
The code that tells us that is   Serial.begin(19200);
cyclegadget: To check your baud rate, look at the bottom right of the serial monitor. It needs to be set to 19200.
I have it set correctly, that is not the problem.
Thanks though, K
So, you may have an inversion/level problem. Have you checked that simpler sketch produces valid results?
The UM6 seems pretty complex with checksums and such for communication. I'd try connecting the UM6 to the arduino tx/tx, rx/rx, and gnd/gnd on the arduino pins 0 and 1. Don't have any code running on the arduino that responds to serial commands. Set the serial monitor to 115200 baud, and send the UM6_GET_FW_VERSION command and see if the version gets returned.
from the data sheet: The UM6 can be queried to determine the firmware version on the device by sending a UM6_GET_FW_VERSION command to the sensor. The UM6 firmware version is stored as a fourbyte sequence of characters. For example, the initial firmware release for the sensor is version "UM1A". Subsequent release versions increment the last letter: "UM1B", "UM1C", etc.
By default, the serial baud rate is set at 115200 baud, but the baud rate can be changed by the end user if desired by writing to the UM6_COMMUNICATION register.
Communication with the UM6 is performed over either a TTL (3.3V) UART or a SPI bus.
Thank you very much zoomkat, That seems like a good plan. My biggest problem is that I do not know how to write to the UM6_COMMUNICATION register. Could you possibly explain how to do this?
Much appreciated, Kyle
No, as this is the first I’ve heard of this gizmo. Your best bet may be to find a discussion group for it. Otherwise, study the data sheet and working code for insights on the communication methods.
