I am trying to connect an Arduino to a digital accelerometer. The Arduino receives commands from a mobile app and transmits over Bluetooth through hardware serial.
Code:
#include <SPI.h>
const int X8 = 0x06;
const int Y8 = 0x07;
const int Z8 = 0x08;
bits
1 0 mode 00: standby, 01: measurement
5 1: spi 3 wire, 0: 4 wire
4 self test
3 2 glevel: 01 2g
1 0 mode, 00 standby, 01 measurement
const int MODE = 0x16;
const int STATUS = 0x09;
//7 digital filter band width, 0 62.5 Hz, 1 125 Hz
const int CONTROL = 0x18;
bool isTesting = false;
const int chipSelectPin = 7;
SPI.begin();
pinMode(chipSelectPin, OUTPUT);
//set up standby, spi 4 wire, 2g range,
writeRegister(MODE, 0x04);
//set up speed
writeRegister(CONTROL, 0x00);
delay(100);
if(getSerial() == 't')
isTesting = true;
writeRegister(MODE, 0x05); // 0000 0101- 0001 0101 0x15
testing();
void testing(){
while (isTesting ){
if ((readRegister (STATUS) & 1) == 1 ){
Serial.print((char)readRegister (X8),DEC);
Serial.print("x");
Serial.print((char)readRegister (Y8),DEC);
Serial.print("y");
Serial.print((char)readRegisterChar (Z8),DEC);
Serial.print("z");
if (getSerial() == 'u'){
isTesting = false;
char getSerial(){
if (Serial.available()){
char c = Serial.read();
return c;
return 'x';
byte readRegister (byte thisRegister){
byte inByte = 0 ;
SPI.beginTransaction(SPISettings(500000, MSBFIRST, SPI_MODE0)); // 500khz clock
digitalWrite(chipSelectPin, LOW);
SPI.transfer(thisRegister << 1);
inByte = SPI.transfer(0x00);
digitalWrite(chipSelectPin, HIGH);
return inByte;
char readRegisterChar (byte thisRegister){
char inChar = 0 ;
inChar = SPI.transfer(0x00);
return inChar;
void writeRegister (byte thisRegister, byte value){
SPI.transfer(128 | thisRegister << 1);
SPI.transfer(value);
The sensor allows for data values of 10 bits but for simplicity I am getting only the 8 bit data. The data received when the sensor is on a flat surface is:
- x y z
- 5 -11 74
- 4 -19 74
- 2 -9 69
- 0 -8 68
- 7 -16 68
- 7 -11 73
When the self test is run, the results are:
- -5 -20 122
- -4 -22 122
- -1 -20 123
- -4 -20 123
- -5 -21 121
- -3 -18 123
- -8 -22 127
From the data sheet: "When the self-test function is initiated through the mode control register ($16),
accessing the “self-test” bit, an electrostatic force is applied to each axis to cause it to deflect. The Z-axis is trimmed to deflect
1g."
Is the data correct? How is it interpreted? If the z data during self test is 1g, shouldn't it have the same magnitude as when it is on a flat surface?
Thank you.
