Thanks Grumpy_Mike, but I wasn't able to successfully implement this. Here is the code I've been working with:
* IRremote: IRrecvDemo - demonstrates receiving IR codes with IRrecv
* An IR detector/demodulator must be connected to the input RECV_PIN.
* Version 0.1 July, 2009
* Copyright 2009 Ken Shirriff
* http://arcfn.com
#include <IRremote.h>
int RECV_PIN = 10;
IRrecv irrecv(RECV_PIN);
decode_results results;
unsigned long startTime;
uint16_t i=27;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(27, 6, NEO_GRB + NEO_KHZ800);
irrecv.enableIRIn(); // Start the receiver
strip.begin();
strip.show(); // Initialize all pixels to 'off'
if (irrecv.decode(&results)) {
Serial.println(results.value, HEX);
irrecv.resume(); // Receive the next value
switch(results.value)
case 0xFF1AE5:
//colorWipe(strip.Color(255, 0, 0), 5); // Red
colorChase(strip.Color(127, 0, 127), 25); // Violet
case 0xFF9A65:
//colorWipe(strip.Color(0, 255, 0), 5); // Green
scanner(127,0,127, 15); // Violet
case 0xFFA25D:
//colorWipe(strip.Color(0, 0, 255), 5); // Blue
//myCrap(strip.Color(127,0,127),10); //Violet
wave(strip.Color(127,0,127), 2, 40); // Violet
case 0xFF22DD:
colorWipe(strip.Color(255, 255, 255), 5); // White
case 0xFF02FD:
colorWipe2(strip.Color(0, 0, 0), 5); // Off
case 0xFF2AD5:
colorWipe2(strip.Color(255, 0, 0), 5); // Red
case 0xFFAA55:
colorWipe2(strip.Color(0, 255, 0), 5); // Green
case 0xFF926D:
colorWipe2(strip.Color(0, 0, 255), 5); // Blue
case 0xFF12ED:
colorWipe2(strip.Color(255, 255, 255), 5); // White
case 0xFF0AF5:
colorWipe(strip.Color(255, 165, 0), 5); // Orange
case 0xFF8A75:
colorWipe(strip.Color(0, 255, 255), 5); // Teal
case 0xFFB24D:
colorWipe(strip.Color(160, 32, 240), 5); // Purple
case 0xFF32CD:
colorWipe(strip.Color(255, 20, 147), 5); // Pink
case 0xFF38C7:
colorWipe2(strip.Color(255, 165, 0), 5); // Orange
case 0xFFB847:
colorWipe2(strip.Color(0, 255, 255), 5); // Teal
case 0xFF7887:
colorWipe2(strip.Color(160, 32, 240), 5); // Purple
case 0xFFF807:
colorWipe2(strip.Color(255, 20, 147), 5); // Pink
case 0xFF827D:
colorWipe(strip.Color(0, 0, 0), 5); // Off
case 0xFF30CF:
rainbow(5); // Rainbow
case 0xFF708F:
rainbowCycle(10); // Rainbow Cycle
case 0xFF10EF:
rainbowCycle(0); // Rainbow Cycle
case 0xFFB04F:
rainbow2(5); // Rainbow
case 0xFF906F:
rainbowCycle2(10); // Rainbow Cycle
case 0xFF50AF:
rainbowCycle2(0); // Rainbow Cycle
case 0xFF20DF:
rainbowCycle3(10); // Rainbow Cycle
case 0xFFA05F:
rainbowCycle3(0); // Rainbow Cycle
default:
// if(results.value == 0xFF7887)
// colorWipe(strip.Color(255, 0, 0), 50); // Red
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
for(uint16_t i=26; i<strip.numPixels(); i--) {
strip.setPixelColor(i, c);
strip.show();
delay(wait);
void colorWipe2(uint32_t c, uint8_t wait) {
// Henry_Best- for(uint16_t i=26; i<strip.numPixels(); i--) {
if ((millis()-startTime) >= wait) { // Henry_Best:don't do anything if wait time not reached
if (i>0) { // Henry_Best:??does your LED strip end at 0 or 1?? If 1, change to (i>1).
i--; // Henry_Best
strip.show();
// Henry_Best- delay(wait);
else {
i = 27; // Henry_Best:begin again
startTime = millis(); // Henry_Best:reset to NOW for the next wait period.
void rainbow(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256; j++) {
for(i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel((i+j) & 255));
strip.show();
delay(wait);
void rainbow2(uint8_t wait) {
uint16_t i, j;
strip.setPixelColor(i, Wheel((i*j/2) & 255));
strip.show();
delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
for(i=0; i< strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
strip.show();
delay(wait);
void rainbowCycle2(uint8_t wait) {
uint16_t i, j;
strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()/2) - j) & 255));
strip.show();
delay(wait);
void rainbowCycle3(uint8_t wait) {
uint16_t i, j;
strip.setPixelColor(i, Wheel2(((i * 256 / strip.numPixels()/2) - j) & 255));
strip.show();
delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
if(WheelPos < 85) {
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} else if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
WheelPos -= 170;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
uint32_t Wheel2(byte WheelPos) {
if(WheelPos < 85) {
return strip.Color(WheelPos * 3, 25 - WheelPos * 3, 0);
WheelPos -= 85;
return strip.Color(25 - WheelPos * 3, 0, 25 - WheelPos * 3);
WheelPos -= 170;
return strip.Color(0, WheelPos * 3, 25 - WheelPos * 3);
// Chase one dot down the full strip.
void colorChase(uint32_t c, uint8_t wait) {
int i;
// Start by turning all pixels off:
for(i=0; i<strip.numPixels(); i++) strip.setPixelColor(i, 0);
// Then display one pixel at a time:
strip.setPixelColor(i, c); // Set new pixel 'on'
strip.show(); // Refresh LED states
strip.setPixelColor(i, 0); // Erase pixel, but don't refresh!
delay(wait);
strip.show(); // Refresh to turn off last pixel
// "Larson scanner" = Cylon/KITT bouncing light effect
void scanner(uint8_t r, uint8_t g, uint8_t b, uint8_t wait) {
int i, j, pos, dir;
pos = 0;
dir = 1;
for(i=0; i<((strip.numPixels()-1) * 8); i++) {
// Draw 5 pixels centered on pos. setPixelColor() will clip
// any pixels off the ends of the strip, no worries there.
// we'll make the colors dimmer at the edges for a nice pulse
// look
strip.setPixelColor(pos - 2, strip.Color(r/4, g/4, b/4));
strip.setPixelColor(pos - 1, strip.Color(r/2, g/2, b/2));
strip.setPixelColor(pos, strip.Color(r, g, b));
strip.setPixelColor(pos + 1, strip.Color(r/2, g/2, b/2));
strip.setPixelColor(pos + 2, strip.Color(r/4, g/4, b/4));
strip.show();
delay(wait);
// If we wanted to be sneaky we could erase just the tail end
// pixel, but it's much easier just to erase the whole thing
// and draw a new one next time.
for(j=-2; j<= 2; j++)
strip.setPixelColor(pos+j, strip.Color(0,0,0));
// Bounce off ends of strip
pos += dir;
if(pos < 0) {
pos = 1;
dir = -dir;
} else if(pos >= strip.numPixels()) {
pos = strip.numPixels() - 2;
dir = -dir;
void myCrap(uint32_t c, uint8_t wait) {
for(uint16_t k=0; k<strip.numPixels(); k++) {
strip.setPixelColor(2*k, c);
strip.show();
delay(wait);
Any possibility of implementing myDelay here?
