Connect TCP and send GET request.
- This example is used to test DFRobot_SIM808 GPS/GPRS/GSM Shield's connect TCP and send GET request.
- Open the SIM808_TCPConnection example or copy these code to your project
- Download and dial the function switch to Arduino
- Open serial helper
- Waiting for a few minutes, until serial has sent "Connect mbed.org success"
- Serial will send "Hello world!"
create on 2016/09/23, version: 1.0
by jason
#include <DFRobot_sim808.h>
#include <SoftwareSerial.h>
//#define PIN_TX 10
//#define PIN_RX 11
//SoftwareSerial mySerial(PIN_TX,PIN_RX);
//DFRobot_SIM808 sim808(&mySerial);//Connect RX,TX,PWR,
//make sure that the baud rate of SIM900 is 9600!
//you can use the AT Command(AT+IPR=9600) to set it through SerialDebug
DFRobot_SIM808 sim808(&Serial);
char http_cmd[] = "GET /api/agents/[variable RFID] HTTP/1.0\r\n"
"Host: [mode edit, possible spam removed]\r\n"
"\r\n";
char buffer[512];
void setup(){
//mySerial.begin(9600);
//******** Initialize sim808 module *************
while(!sim808.init()) {
Serial.print("Sim808 init error\r\n");
delay(3000);
//*********** Attempt DHCP *******************
while(!sim808.join(F("cmnet"))) {
Serial.println("Sim808 join network error");
delay(2000);
//************ Successful DHCP ****************
Serial.print("IP Address is ");
Serial.println(sim808.getIPAddress());
//*********** Establish a TCP connection ************
if(!sim808.connect(TCP,"[mode edit, possible spam removed]", 80)) {
Serial.println("Connect error");
}else{
Serial.println("Connect [mode edit, possible spam removed] success");
//*********** Send a GET request *****************
Serial.println("waiting to fetch...");
sim808.send(http_cmd, sizeof(http_cmd)-1);
while (true) {
int ret = sim808.recv(buffer, sizeof(buffer)-1);
if (ret <= 0){
Serial.println("fetch over...");
buffer[ret] = '\0';
Serial.print("Recv: ");
Serial.print(ret);
Serial.print(" bytes: ");
Serial.println(buffer);
//************* Close TCP or UDP connections **********
sim808.close();
//*** Disconnect wireless connection, Close Moving Scene *******
sim808.disconnect();
void loop(){
